truck 5.3 power steering pump
Car: 1989 iroc
Axle/Gears: 2.77
does anyone know if the power steering pump and bracket from a 5.3 truck engine the same as the camaro ls1? thanks
Transmission: 4L80E/4L80E
On the f-body, the PS pump is high and the alternator low. On the trucks, the alternator is high and the PS pump low. So, the brackets would be different.
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Re: truck 5.3 power steering pump
I'll second what five7kid said. You can't mix and match accessories. Corvette accessories are different than Fbody accessories, and truck accessories are different than both Corvette and Fbody accessories. The difference is how far the belt is away from the engine. Truck accessories put the belt furthest away, Corvette puts it closest, and Fbody is in the middle. Also, truck accessories won't work in a thirdgen; the alternator will hit the hood unless you have a big/wide/long cowl (like the Jongbloed) or you modify the alternator mount. For a thirdgen swap, you'd be best off going with Fbody accessories. They're relatively cheap and easy to find used. Register on LS1tech and watch the classifieds for deals. LS1tech has a huge amount of info on this and other swap topics. They even have a whole section dedicated to conversions.
Car: 1989 iroc
Axle/Gears: 2.77
the pump is for sale on ls1tech. i currently have a ls6 longblock minus the acc. and pcm, wiring harness. i am collecting all the parts required and reading all the swap post on tgo and ls1tech. thanks for all the help.
Car: '84 Camaro
If you feel like dropping a little coin, this setup would get you on your with brackets and bolts. You could then buy the water pump, power steering pump, and alternator used without worrying about bolts and junk.
I've done quite a bit of research on this for my swap, so if you have any questions feel free to PM me.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
In the May 2009 issue of Car Craft, they have an article about the LS series engine accessories. they said the alternator is the only accessory interchangeable between the ls1 and 5.3. So if your 5.3 came with the alternator, keep it you can reuse it with the f-body bracket.
Trucks use the same pump as your 3rd gen, heavy duty designed for steering boxes. LS1's use a compact pump common on RNP steering systems. Totally different
Also, keep in mind the truck belt drive offset is different
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
