what fuel pump???????
Car: 92 rs ls1/4l60, 99 z28
Engine: ls1
Transmission: auto & manual
Axle/Gears: 3.42 & 3.90
im swaping a 02 ls1/a4 into a 92 camaro rs with a tbi 305. im needing to know what in tank fuel pump i need.... (besides the hawks $180.00 pump) can i just get one from autozone or advance auto? will a tuned port 5.7 pump work?
need info......like part numbers or whatever....thanks!
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
A stock replacement TPI pump will do the job. A Walbro 255 would do a better job.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: what fuel pump???????
Hey, as five7 said, Welcome aboard!
As long as you're going to be going to the work of replacing the pump, I'd honestly suggest that you just get the Walbro 255 pump & call it good. The stock TPI pump will work, but you're going to find it's limits a lot more quickly than the more-capable pump.
And speaking only for myself, I find that I get distinctly annoyed when I have to go back & re-do something...
Engine: ls1
so a walbro 255 will fit on my TBI pump assembly.....thanks guys...
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
If using the stock 3rd gen tank, (I have a TPI car) Can I just swap in a walbro 255 lph pump and use a corvette fuel filter for the regulator? Does the sending unit or anything have to be modified for the pump to fit or is it a direct plug and play drop in? I'd like to go 4th gen tank, but can't seem to find much in my area, and shipping is killing me on all these parts I am buying online.
Yes, the Walbro will fit in the pick-up without (major) modification, and you can use a Vette filter as the regulator.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I want to publicly thank Aaron91RS for shipping the pump well-packed, and in a timely manner.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The used stock LSx pump. I need to test my fuel fittings at the full 60 psi. I have a used TPI pump that only makes a little over 40 psi, but the LSx requires at least 58.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
