Motor Mounts?
Old Mar 26, 2009 | 04:59 PM
83trnsamLT1's Avatar
Car: 1983 Trans Am Recaro
Engine: Lt1
Motor Mounts?
I'm putting a 94 Lt1 into a 83 trans am, which motor mounts would work. the motor mounts off the 94, or can I stick with the motor mounts for the 83.
Old Mar 26, 2009 | 06:25 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Motor Mounts?
Better to use the '83 mounts, with poly inserts from Energy Suspension
Old Mar 26, 2009 | 07:15 PM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
Re: Motor Mounts?
I just did this swap on my 85 Z28. Use the third gen mounts but while you are there upgrade to the poly inserts. I went with solid mounts and it may be a little rough for alot of street use.
Old Mar 26, 2009 | 07:24 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Motor Mounts?
I run solid mounts, but my engines are balanced to within one gram. GM engines are nowhere near smooth enough. Using solid mounts requires using LocTite on every fastener of everything attached to the engine. Do NOT try solid trans mount.
Old Mar 26, 2009 | 08:45 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Re: Motor Mounts?
^^ def go that route. solid mounts are gonna shake ur car apart (not literally). I have a mildly built LTx motor in my car and you should see the amount of engine torque while its idleing, i could only imagine what that would feel like with solid mounts.
Old Mar 27, 2009 | 05:37 PM
ghostinme's Avatar
Car: 92 camaro rs
Engine: carbed LT1
Transmission: 4l60e
Axle/Gears: stock
Re: Motor Mounts?
there are mounts for the swap on hawks third gen they are by spohn and a lil pricey i just got mine they are nice.. i was also told in 3rd gens u can use the standard 350 mnts if u have then but i am not sure i have read u can but i think most use the hawks mnts..
Old Mar 27, 2009 | 11:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No need for "swap" mounts with an LT1.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
