96' Camaro ALDL
Old Apr 9, 2009 | 05:09 PM
6772owner's Avatar
96' Camaro ALDL
Ok guys I have read about everything I could find doing searches and cant seem to answer my specific question.....
I have a 96' LT1 I swapped in my p/u and I cant get a code scanner to link to the PCM.
I have checked the ground(s) to the PCM/ALDL moved the ground to better spot, checked the wires from the ALDL to the PCM pin outs with a testlight (With the connectors unplugged from the PCM obviously) and I also verified the Diagnostic Request wire was intact. Now I did cut the request wire to install the ALDL and had to solder it back together (if this helps)
Whatelse do I do/check?
I also believe that the PCM is ok, I had the VATS programmed out by putting the PCM in a donor Camaro to verify its function. The engine also runs very well, just constant SES light (due to lack of further tuning) and no link to the Code Reader.....
Please help.... Thanks in advance.
Old Apr 15, 2009 | 08:14 AM
6772owner's Avatar
Re: 96' Camaro ALDL
Nobody???
Old Apr 17, 2009 | 09:32 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: 96' Camaro ALDL
Here's a bump back to the top for ya, good luck.
Old Apr 28, 2009 | 12:32 PM
6772owner's Avatar
Re: 96' Camaro ALDL
Thanks for the bump, I finally found a useful wiring diagram and I didnt have the purple serial wire(class II) hooked up to PCM, works now.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
