gauges
Old Apr 15, 2009 | 08:55 PM
irocboy8292's Avatar
Car: 1986 Camaro Z-28
Engine: 3970010--5.?l
gauges
hi i need to run the gauges on my 86 z28 after dropping in a lt1.. does anyone have the schematics to know which wire is for each gauge and which wire i connect it to on my lt 1 harness.. my motor and harness from a fleet wood... thanks this will help out alot
ps just need tach, oil psi, temp and voltage
Old Apr 16, 2009 | 02:56 PM
Re: gauges
bump
Old Apr 17, 2009 | 03:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: gauges
LT1 harness will not control your gauges aside from speedo/tach
They are salvaged from your original harness
http://www.austinthirdgen.org/index.php?pid=19
Use this as a reference
Old Apr 20, 2009 | 06:34 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Re: gauges
The wires for the gauges should be in the 10 pin white connector that is attached to the lt1 harness. Label the ones you need and then splice them into the bulkhead wiring from your car. Only ones you need are A,C,H,K. H is under your dash though. The other 3 will come out of the bulkhead connector and they are the same color.
Old May 1, 2009 | 09:24 AM
Re: gauges
oh thanks alot where could i find the wires coming from the gauges the factory ones are they going into the engine compartment as well?
thanks alot though
Old May 1, 2009 | 02:55 PM
Pocket's Avatar
Car: 91 Trans Am
Re: gauges
Most gauge wiring is thru the C100
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
