Hawks A/C Line Kit for LS1 Conversions
Just wanted to drop a line and let you guys know we just got in our A/C line kits for 3rd Gen LS conversions. This will allow you to connect your LS1 A/C Compressor to your 3rd Gen Condenser. Here is a link to it...
http://www.hawksthirdgenparts.com/ls...passkit-1.aspx
Thanks, Steven
Hawks
Thanks, Steven
Hawks
Transmission: 4L80E/4L80E
Must be why I haven't done anything with mine yet. . .
I assume it uses the 3rd gen receiver/dryer.
Which pressure switch does it use? I don't see a place for the LS1 switch.
Re: Hawks A/C Line Kit for LS1 Conversions
Yes it does use the 3rd Gen receiver and dryer...
You will have to use the preasure switch that is on the 3rd Gen dryer, but on the high side which is the small metal line you will hvae to use the 4th Gen switch which is a 3 wire connector.
Thanks, Steven
Hawks
Thanks, Steven
Hawks
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Any chance this would work on the LT1 swaps? I know alot of people that have the LT1 swaps would love this.
This kit wont work, different setup, is there a demand for these? How bout this, if I can get 10 orders for the LT1 A/C Line kit I will sell them for $125 each instead of $149. Let me know...
Car: Camaro
Engine: 6.2L
Nice. Almost identical to what I made up save for I used 4th gen engine side and third gen chassis side and welded them together. This makes it a hella lot easier for future swappers and even though I have all the tools to do what i did, scrounging for used 4th gen ac lines was a pita and I would have jumped all over these if I had the option.
Car: 91 Firebird
Engine: 6.0
Definitely a nice option to have.....
I prolly would've kept my ls ac setup if this was available.... definitely cheaper than the brackets I bought
-jason
-jason
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Have you verified this will work when using stock f-body manifolds? I would like to use them but what if they don't fit...
On another note, what supercharger is that? LM Speed?
Car: 1987 GTA
Myself, I have to do something different since I have a 4th gen condensor in my car.
Your picture shows the 3rd gen switch connector hanging loose. And, I still don't see the LS1 switch or where it would go.
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Granted you could do that, but from my understanding if you provide +12v to the wire which tells the PCM that the compressor is on the PCM will do its job of turning on fans and managing idle. Of course this means it can't turn the compressor off but avoids using another pressure sensor.
I have not tested this myself but will be shortly.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Im thinking you could eliminate all of the 3rd gen switches all together. I mean...thats how Im running my a/c set up, except I used all stock LS1 hoses and parts.
Wiring is SOOOO simple compared to the 3rd gen set up with hi and low pressure switches. Since the PCM tells the a/c compressor what to do, you really only have to wire the PCM a/c request wire to the wire from your stock HVAC controls that would normally trigger the 3rd gen a/c. The PCM handles the rest...cycling, fans, idle....everything. Basically if I want to disable my a/c, I just disconnected one wire up by the HVAC box. The "trigger wire" from the 3rd gen wiring is the wire that comes into the low pressure switch I believe.
The HVAC wiring in our cars is self contained so its easy to work with. And the LS1 harness contains the A/C wires already. Its a cake walk from there. Only hiccup there could be if the hard parts (drier/evap/condenser) function differently on the 3rd gen...then maybe you'd need the low pressure switch. But I dont think you will.
On a side note...I kinda wish these lines were around back when I did mine. I probably would have avoided building my own HVAC box and going through all that mess.
J.
J.
Car: 86 Trans AM
The 4th gen switch can be seen in the picture. Look down sorta next to the headers. Its screwed into that hard line that snakes up the chassis rail and comes up to the evap. Its just the switch a plug..wires are cut.
The black cap on the front of the drier is the low pressure connection, and the cap on the hardline is the high pressure connection.
J.
Car: 1987 GTA
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
so you use the 3rd gen condenser.. wut accumulator would you use ? and is there any way to use the 4th gen hvac controls?
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Thanks, Steven
Hawks
Thanks, Steven
Hawks
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
This is a work in progress, he had to cut the firewall as well to get it to fit good, it was cool though the dash bolted right up. Haha...
He doesnt have any of the low pressure switches screwed into the drier...but he's saying you'd put the thirdgen low pressure switch in the stock location....rear side of the drier.
J.
J.
From what I've been able to gather, the 3rd gen A/C control is wired directly to the PCM "A/C Request" wire. The LS1 harness does the rest (assuming the LS1 switch is mounted in the line and wired properly in the LS1 harness).
Okay, I see the 4th gen switch now. But, that line doesn't look like my 3rd gen line, and doesn't look like the line in the kit. So, I still don't have a place to mount the 4th gen pressure switch.
Car: 86 Trans AM
... if you want to use the 4th Gen HVAC you will have to use a 4th Gen A/C box and you might as well put a 4th Gen dash in it like this... See Attached
....unless you are already doing the dash swap, then there is def a good reason to try to fit the whole box.
However...if your lines were available, I probably would have gone with them instead of what I did.
I actually gave thought to cutting my firewall and working in the 4th gen HVAC box. Just didnt want to do that much cutting on the firewall.
J.
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
I am working on a compressor block/hoses that will work with the factory manifolds. Do you know the threads need to connect to the dryer and the condensor? I have the originals here but I don't know the threads and sizes.
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I also used my third gen chassis side, and my LS1 compressor. With my Speartech wiring harness my ac is controlled with the stock HVAC controls. I welded the 3rd gen fittings on the 4th gen lines to hook it up. I have heard the lines are backwards on the condensor itself, 3rd gen versus 4th gen. Does anyone know anything about that? I dont want mine to crap out on me.
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Anyone else have reviews on these lines? I've found plenty of threads where people suggest to use these, or they get a custom set made, but haven't found any that actually used these by Hawks? Are they on the long side?
I was originally going the custom hose route with a compressor block from acsourse, but am not happy with the fitment (interferes with the mounting bolt) nor the quality. Hawks looks like it's close, but I assume there's enough threads to get the fitting on.
Car: 91 Firebird
Engine: 6.0
My Hawks kit fit the same as the pic above. I had to remove that bolt to thread the hose on......
Car: 1986 Z28
Transmission: T5 WC
Hmm. Thanks.
Requiring removing the bolt kinda defeats the purpose for both Hawk's and the one from acsourse. Since the Hawk one is (now) a machined piece, I'd imagine they could extend the neck another 1/2" or so, or rotate them 15*
Car: '89 Firebird
Engine: 7.0L
Car: 1990 Camaro RS
Engine: L31
I had my third gen lines welded to the fourth gen lines. It's a bear to get install, but it works fine.
I just marked and cut the lines where I need them and also made marks so they would be clocked properly when welded.
ambainb
Apr 25, 2016 09:21 PM
