ls1 swap eng mount advice
Old May 5, 2009 | 07:17 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
getting ready to order some lsx swap eng. mount and trans cross member for ls1 and 4l60e swap. which brand do you that have the swap recommend? thanks
Old May 5, 2009 | 07:22 AM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: ls1 swap eng mount advise
i did a t56 swap, but i used the frame mounts i picked up from Hawks, and used them with poly mounts on the block and a skulte x-member. worked well. motor/frame mounts should work fine for your swap.
Old May 7, 2009 | 07:57 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
The "brand" that I recommend is Spohn. You can buy them at Hawks....or direct from Spohn. Either way, they'll work.
Be prepared to have tight clearance between the oil pan sump and k-member...unless Steve started building the mounts alittle different. I ended up pulling my k-member back out and cutting and welding a notch in place for the pan. No big deal if you've got the car apart.
J.
Old May 7, 2009 | 10:09 AM
Car: 1989 iroc
Axle/Gears: 2.77
thats was what i was curious about. if somebody makes them for better clearance and if there is a difference
Old May 11, 2009 | 07:34 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I used 1" setback adaptor plates. didn't even have to take my mounts out the car which was good for me since I had just put new ones in. didn't have to notch for oil pan or nothing. only thing is the stock ac compressor won't work like this. I just created a thread about a mount for the sanden ac compressor that will put it in the same place as the stock without even having to notch the k-member. check it out.
Old Aug 19, 2009 | 04:25 PM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Re: ls1 swap eng mount advice
Well that all sounds good but has anybody put..the LSX in the 3rd gen. using a K-member from BMR that was made for a small/big block appli. Thats what I have and dude a BMR said that a LS1 bracket should work with the K-member..any ideas or where to look!!!tks
Old Aug 19, 2009 | 07:21 PM
Pocket's Avatar
Car: 91 Trans Am
A tub K member with SB/BB mounts acts just like a factory K member, so you will need the swap mounts(bolt on) to drop your LS1 in
Old Aug 26, 2009 | 09:36 PM
Cg-OneSic89's Avatar
Car: 1984 Z28 L69
Engine: Cammed 350
Transmission: Tremec Tr-3550
Im going with a Brp Hotrods Kit, albeit a bit pricey they pick then engine up a little more then the hawks kit and sit it slightly back. They claim itll clear the ac compressor from a Fbody setup. It also frees up enough room to run brps headers that run from 1 3/4 to 2in primarys. Most of this info is on the site, the only thing i am concerned with is the quality of the trans crossmember. It looks a bit weak in the picture and i have yet to call and ask if the will warranty it behind a strong 11 second daily motor.
Good luck with your swap, hope this helped.
Old Aug 27, 2009 | 09:27 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
If you want lots of clearance, get the Spohn tubular k-member. I have a group purchase going on with Hawks for $50 off. We need I think two more people!
Old Aug 28, 2009 | 05:55 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
blue zee,
thanks but i already bought the spohn mounts and i am finally dropping my engine in this weekend.
Old Aug 29, 2009 | 04:07 PM
92tracker's Avatar
Car: 92 firebird formula
Engine: 2002 LS1/6 350 rwhp
Transmission: 4L60e
Axle/Gears: 342
do your self a favor put about a quarter inch of shim in the bottom half of the mounts to raise it up slightly this will help when it comes time to install the A/C comp if you plan on putting one on. The trany mount I ended up making a modified vertion of this with 1.5 inch tubing and angle mostly for clearance so the exhaust could run through easier.
Good luck on your swap
xkingcodex
Feb 12, 2020 07:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
