02 TA 4L60e trans cooler line fitting
Old Jun 4, 2009 | 04:47 PM
screeminchicken's Avatar
whats the thread size or fitting size that comes in a 4L60E ? would it screw into my stock third gen radiator.
I dont have a radiator yet to do a test
Old Jun 4, 2009 | 08:22 PM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: 02 TA 4L60e trans cooler line fitting
I want to say its the same size fitting as the 700, so it will work. I'm stopping by the parts store tomorrow to pick up new hoses for my cooler lines. So i'll let yah know then
Old Jun 5, 2009 | 12:17 PM
thanks man, I have an 82 and I have read the thread fittings for that was different.
I also heard that the later 3rd gens had similar fittings as 4th gens .
Thinking about it , I will run into the same issue with brake lines, power steering and maybe A/C.
I just need somebody to confirm that.
Old Jun 5, 2009 | 12:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'82-'83 brake lines were SAE double flare. '84-up were metric bubble. I'm keeping all of my '82 brake lines, but I'm not changing the rear, either. However, I did put later rears in the '82 Berlinetta #1 by changing the hydraulics back to '82 stuff.
Power steering fittings didn't change.
AC really depends upon what you do. It's pretty much completely different between 3rd and 4th gen, so some modification is required regardless.
84z96L31vortec
Aug 20, 2017 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
