ebay harnesses
Old Jun 26, 2009 | 02:16 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
ebay harnesses
well i'm not having much luck finding a used ls1 harness, so i am thinking about going with a new one off ebay. just wondering if anyone on here has any experience with the ebay harnesses? they of decent quality? found two sellers, both in the $300 range, for the basic harness anyway. just kinda curious what you guys think. thank, nick.
Old Jun 26, 2009 | 02:32 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: ebay harnesses
Check on Ls1tech
I know a few guys have tried them. You *might* be better off having someone build you a conversion harness rather than just buying a stand alone harness
Just depends on how much you want to spend
good luck with it
-jason
Old Jul 10, 2009 | 08:20 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Re: ebay harnesses
I used a stand alone harness with great success.
http://www.ls1wiringharness.com/
I posted a review elsewhere on this forum.
Old Jul 10, 2009 | 10:11 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: ebay harnesses
SERIOUSLY man - ebay harnesses are pretty "hit or miss". Sometimes you'll see someone talking about a good one they've gotten, but it seems that just as often you hear people b!tching about 'em.
Personally, I bit the bullet & bought a new harness to modify myself from GM, but if that doesn't appeal to you, your next-best option is probably to buy one from a vendor that's known to be reputable (hint: Speartech has built a really good reputation).
(EDIT: I'd agree with the previous person who suggested looking on LS1Tech - a bit earlier this afternoon I posted that I was looking for LS-series F-body exhaust manifolds, now I have two sets to choose from...)
Good luck.
Old Jul 10, 2009 | 10:28 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: ebay harnesses
how's that work it says it doesn't even contain the part of the harness for the tranny?
Old Jul 10, 2009 | 11:04 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: ebay harnesses
If you go to the f-body ls1 tab you'll see 3 different wiring harnesses. The first one does not have wiring for the transmission, the second one is for use with a 4L60E trans, and the third harness is for using the t-56. I bought their harness as well, it looks very professional and the only complaint I have is that I wish they made the diagnostic connector long enough to reach the driver side dash.
Old Jul 11, 2009 | 09:47 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
Re: ebay harnesses
i bought this harness.
http://cgi.ebay.com/ebaymotors/ws/eB...m=160344443727
it comes with a instruction cd and appears pretty simple.
i have not hooked it up yet thou. just pulled engine and started swap.
Old Jul 11, 2009 | 10:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have my eye on them, too. Let us know how that works out. I'm short one PCM & harness for my projects, so if this is any good, it would do me well.
Old Jul 11, 2009 | 11:49 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: ebay harnesses
Hey five7, is the harness the same for all years of the ls series engines? will the ls1 harness work with you lq4?
Old Jul 11, 2009 | 05:08 PM
five7kid's Avatar
If the seller matches the connectors and programs like he says he will, it should.
People use LS1 harness/PCM on LQ4's all the time.
Old Jul 11, 2009 | 06:54 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Re: ebay harnesses
They would have if you had asked The guy is very helpful.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
crystal383
Interior Parts Wanted
Sep 22, 2015 01:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
e3pres
Sep 9, 2015 01:51 PM
Billy Decker
Sep 4, 2015 03:46 PM
