aquired an ls 5.3
Old Jul 7, 2009 | 10:15 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
aquired an ls 5.3
so at work, we pulled a 5.3 out of an isuzu ascender, it spun a rod bearing.
im trying to find a good crank and 1 rod if i can, to breathe new life into my free mill. i dont have any experience with these mills, any links or parts dealers would be appreciated.
btw, not planning on puting this in my maro, going to my 1500 p/u
Old Jul 7, 2009 | 12:11 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: aquired an ls 5.3
you should join www.ls1truck.com
Old Jul 7, 2009 | 12:56 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Since its a 5.3, a crank from most any LS1 or 6 liter will do. Depending on the year of the 1500 its going in will dictate what you need to look for in regards to the reluctor wheel on the crank. Depending on the year you could even get a crank from an LS2 as well but you should research that first.
Old Jul 7, 2009 | 01:32 PM
well its an 05 engine and a 91 gmc step side. shouldnt be a problem. i found a stroker kit from lunati, but that shlt is 4k. stock is all i need, but i cant find anything, and most salvage yards just sell the entire short block.
just found out this is a 5300 lm4 aluminum block if that matters.
ZZ3Astro
Aug 13, 2019 12:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
