Ls1 question
Old Aug 2, 2009 | 03:47 PM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Ls1 question
I have a Ls1 engine and I have found a deal for both ls6 parts and ls2 parts would I have to do anythig to the ls1 block to make it work and if not what would you guys recomend using out of the two choices I have?
Old Aug 2, 2009 | 06:00 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Ls1 question
Nearly everything in the LSx family will interchange
What are you debating?
Check the LTx/LSx swap forum for more info and ls1tech.com
Old Oct 16, 2009 | 07:06 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Re: Ls1 question
Which one would be better to use with the ls1 block that i have.
Old Oct 16, 2009 | 07:12 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Ls1 question
One thing that might be worth considering, is that you'll need to keep the LS1 throttle body. The LS2 and LS6 both use a drive-by-wire TB, while the LS1 has a throttle cable. If you wind up with an LS2/LS6 TB, you might be able to swap the cable drive guts onto it, but I'm not sure.
Old Oct 16, 2009 | 11:49 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
The LS1 TB will fit the LS6 intake manifold, which is about 10 hp better than the LS2 intake. All of the LS6 stuff is compatible with your LS1 block, but on the LS2, some things were repositioned. Best to use the LS6 stuff, then sell whatever's left over.
Old Oct 16, 2009 | 12:00 PM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Re: Ls1 question
Alright thanks for the helpful information.
Old Oct 16, 2009 | 12:15 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Ls1 question
LS2/LS6 heads are the same heads. casting number 241
The LS6 and LS2 intakes both make the same power from what I understand, The LS6 is a bolt on no probs, the LS2 is not compatible with the LS1 TB.
Old Oct 16, 2009 | 12:40 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
Not so. LS6 heads were 243s with hollow intake valves and sodium-filled exhaust valves. LS2 heads were also 243s, but with normal valves.
Old Oct 16, 2009 | 12:41 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
And Ken Duttweiler did the dyno testing that proves the LS6 intake is 10 hp better than the LS2 intake.
Old Oct 16, 2009 | 12:59 PM
Re: Ls1 question
My bad, stock ls1 heads are 241, the LS6/2's are the 243. I was just meaning they are the same casting.
Old Oct 16, 2009 | 01:54 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
I hate to seem unfriendly, but again, this is not so either. The 243s has different intake ports and different combustion chambers. The 243s not only have better flow, they also have better mixture / charge motion in the combustion chambers which by itself would help power, even without the improved flow, though the extra flow does help also. The 241 head has 66.67cc chambers, while the 243s are 64.45cc, according to GMPP. 243s are better, but will bolt right in place of 241s.
Old Oct 16, 2009 | 02:15 PM
Re: Ls1 question
No need for an apology! If I am wrong then i am wrong, thank you for sharing information. :-) I think there is confusion with my post though.
I was saying the the 243's are the better casting the 241's The 243s are the LS2/6 (LS6/2 are the same casting, different valves, but the same springs) and the 241s (a different casting) is the LS1 casting.
Old Oct 16, 2009 | 02:28 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
now we're good.
Old Oct 16, 2009 | 03:26 PM
Re: Ls1 question
now we're good.
Sometimes I don't always type what is in my brain. haha
I didn't realize the valves for the LS2 dubbed 243s had upgraded valves though, that is good to know.
Old Oct 17, 2009 | 11:27 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Ls1 question
The LS2 got the same valves as the LS1, but the same castings as the LS6. The LS6 valves didn't get installed in anything but LS6s.
Old Dec 4, 2009 | 07:06 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Re: Ls1 question
Okay I decided to go with the ls6 parts but I do still have questions about set up's i was thinking about and could still use some input on it if that's okay
Old Dec 4, 2009 | 07:27 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Re: Ls1 question
What i am debating on is buying a fast intake and giving the ls6 heads when i get them a stage 1 port job. Im wondering what MM intake would be best to use with the ls1 throttle body you guy's where talking about earler and can i still use the stock ls6 cam or do a have to replace it.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
