VATS questions
Old Aug 4, 2009 | 07:41 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
VATS questions
i put an lt1 in my 86 camaro from a 94 caprice 9c1. i have the whole harness from in a 94 lt1 car hooked to my lt1, (however the only fuses in the in-car fuse block is the Pass-key) but the VATS module is from a 94 roadmaster that uses a resistor key. i have been trying to find a 9c1 vats module to hopefully solve my problem ( i accidently scrapped the caprice parts car i was using before i was certain i had everything-oops!). i was wondering if my motor will start if i touch the resistor feed and return to the proper resistor from a key(how many different resistors are there 4 the pass-keys?) . Most important though, i think its the vats that is the problem and am not sure. i have power to everything in my engine harness but the injectors arent coming on and i have no spark- if i am wrong please let me know.
Old Aug 6, 2009 | 06:18 PM
Engine: vortec 5.7
Re: VATS questions
if it helps its also known as pass-key....does anyone know if this is my problem so i have more certainty in my conclusion and does anyone know how to bypass or just fix my problem?
Old Aug 15, 2009 | 11:55 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
Re: VATS questions
I am almost positive your injector problem is due to your VATS issue, not sure about the spark problem though. I haven't checked it out myself, but you could look into getting a VATS bypass module. Check out Hawks.
http://www.hawksthirdgenparts.com/va...nversions.aspx
I think Ecklers Camaro has them cheeper, but I'n not sure.
http://www.ecklerscamaro.com/
Sorry I couldn't be more help. Hope this gets you on the right track.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
