ls1 grounds
Old Aug 31, 2009 | 06:17 PM
ScorchedPaint's Avatar
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
ls1 grounds
where are the grounding points for the ls1? I am about to fire up for the first time and need to know where the grounds are on the engine? I know the one from the alternator to the frame...... I have my fuse box grounded to the battery and the frame including the relays.
Also, the steam tube is connected to the nipple just below the filler cap nipple, is this ok? I am just trying to see my engine run before i send the pcm out to get tuned. I put the stock headers back on minus the egr? will it still fire?
thanks
Old Aug 31, 2009 | 09:40 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: ls1 grounds
Grounds:
back of passenger head to frame
battery to engine block (big one here)
alternator to frame
The nipple just below the filler cap nipple is where my steam tube is run and it works fine. My egr is capped on the stock manifolds as well. Have fun!
Old Aug 31, 2009 | 09:52 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: ls1 grounds
Heck, I've just added a whole bunch of grounds between different subassemblies. It's not going to hurt anything except for a tiny bit of weight - & it's such a trivial amount that it's not even worth worrying about!
Old Sep 1, 2009 | 06:45 AM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 grounds
awesome, thanks for the help! will post video soon!!
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
gta892000
Sep 16, 2015 12:37 AM
