exhaust question - let me pick your brains for a moment
Old Sep 17, 2009 | 12:12 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I am picking up a set of the SSW long tubes for the LSX swap with 3" collectors. Here is my dilemma:
A guy that wrecked his LSX swapped 3rd gen is parting the car out. He had these same headers but the exhaust he was running was a 2.5" x-pipe, ceramic coated, dual (gutted) cats, into a ypipe right at the rear end into a Borla muffler.
What I was contemplating was just buying the x-pipe with the cats and letting him keep the y-junction so I could run duals all the way back. Here's my main concern: Is running a 3" collector into a 2.5" x-pipe going to be taking a step backwards in a negative way? What I'm concerned about is losing the gains I would normally see with these headers because the exhaust is going down to a smaller radius.
Let me hear what you all have to say and then I'll decide. What I was going to do is run the duals all the way back into a knock-off GMMG style dual crimped muffler setup.
Old Sep 17, 2009 | 01:25 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: exhaust question - let me pick your brains for a moment
I would suggest just running a y pipe. IMO the hassle of duals on these cars just isn't worth it. Plus they won't make much over a properly designed y pipe.
Old Sep 17, 2009 | 01:36 PM
BlueZee28's Avatar
Well the good thing about this guy's x-pipe is it was already fabbed up with mendrel bent tubing on a 3rd gen, and it runs all the way back to the rear end. So I basically would just have to finish it up with a few more feet of piping.
Old Sep 17, 2009 | 03:52 PM
ssean92's Avatar
Car: sold
I am running a 2.5 ypipe, to a 3" non mandle bent tube to a magnaflow and made 450 to the wheel. So I am sure that it will not hurt you as much as you think
Old Sep 17, 2009 | 04:46 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
don't forget that the further away from the motor the exhaust gasses are, the cooler they are so they compress a bit. so what i'm saying is the step down is not gonna make any real change in power that matters unless this is an all out race car
Old Sep 17, 2009 | 05:29 PM
BlueZee28's Avatar
Not a race car at all, just a nicely equipped street car. I suppose I might pull the trigger on this setup since its only $400...
Vintageracer
Jan 10, 2020 05:33 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
