possible new ls1 swap header
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
this seller sells 3rd gen ls1 swap kits on ebay (BRP MUSCLE RODs). i asked them if they planned on selling any headers. this was his reply:
Im about to release a set for this kit mid september and will be offered up to a 2in primary and a new style of flat collector that is going to give extra ground clerance.
that would be cool if we had another option.
Transmission: 4L80E/4L80E
Their website has been saying for months (at least 6) that new 3rd gen swap headers were coming. Based on their other prices, I wouldn't expect them to be much less than the Hawks.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: possible new ls1 swap header
More importantly, does their proposed design permit fitting cats under a lowered car? cats as in catalytic converters, not house pets for little girls.
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i went to thier site and checked out some other swap headers and you're right they probably will not be much less than hawks,
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I really wish Stainless Works would make the headers in regular steel and not just stainless.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i really wish someone made bigger headers than 1 3/4" since 1 7/8" will pick up a lot more power in a serious buildup. Now I have to hand make a second set of headers this winter in the bigger size since the 1 3/4" is a restriction for me.
Car: 1991 Trans Am
On Probation
Engine: several
Transmission: none
Axle/Gears: none
When PHR dyno'ed a stock LS2, they found 462 HP with 1.75", and 472 with 1.875", so even at that level, bigger is helpful.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Engine: Cammed 6.0L LSX
Yea here in MO all I need to do is pass a visual inspection.
It would be nice to see a set of Longtubes that weren't $800
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
lt are nice for a max effort application, but not so necessary for street use.
i put some togther, that are mid length type with 1 3/4 tubes and 3 in. collectors. they offer better ground clearance and ive made them with vband flange sealing, also the y pipe section is a 3 piece also vband flange sealing. 3 piece because it easier to assemble and package. i think they would make for a good budget street car. and still support up to 500bhp
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
He designs the headers then sends them to heddman to make for him.He does test fit them on cars i have seen one of his g body swap kits in person the ls1 fit nice and no header clearance problems at all.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
does he check them on 4L60e tranny LSX swaps?
Car: 1984 Z28 L69
Engine: Cammed 350
Transmission: Tremec Tr-3550
This,
Im currently building a 346 with a ms4, prc 215's and the larger primaries, or even the stepped option would be an awesome gain over the hawks. But i am as well concerned with 4l60e clearance, although if it clears a t56 i dont see wht they wont clear a 4l60e
Car: Camaro RS/SS
Engine: 5.7 LS1
Car: 1984 Z28 L69
Engine: Cammed 350
The header that hawks sells from Stainless Steel does not fit on the 4l60e. I mean they do but you have to modify the tranny a bit and move the right O2 sensor more towards the y-pipe causing o2 reading problems. its possible but the 4l60e just takes up mostly all the room under the car. Even Hawks said that the L/T were made for T56
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Yes, midtubes are great for stockish motors. Street or race has nothing to do with the header, as both have to Y the same, and my LT's tucked up beautifully.
When it comes down to it LT's make more power, and if you've invested money in your motor (cam, heads etc etc) it would be a waste to then choke it all with some mid tube headers.
Theirs company's that make mid tubes for 4th gens, but we all run LT's. For a good reason
Power! I have LT's, my car is a street car, i wouldnt even think twice about mid tubes cause ive got heads/cam in my car, probably 475-500hp. Supreme Member
Car: Camaro RS/SS
Engine: 5.7 LS1
the 02 sensor just needs to be moved not necessarly to a y-pipe. if u have the skills or hookup it can be put on the collector itself.
just extra work to get these headers to fit a automatic
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
right through my ram air hood....
