LQ9 into IROC... what wiring harness should I look for?
Old Sep 25, 2009 | 10:42 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm about to pull the trigger on a 62k mile LQ9 to swap into my IROC, but it comes without a harness. The junk yard that I'm getting the motor from said that they can't even get me one... they're always cut when the motors are pulled.
So, I'm going to need to look for a harness on my own. Anybody care to educate me on harness differences between LS1/LS2/LQ4/LQ9/ blah blah blah?
In the end I will likely have L92 heads and an LS3 intake/injectors, but that's subject to change 20 times too.
Old Sep 25, 2009 | 10:58 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: LQ9 into IROC... what wiring harness should I look for?
I would pick up a harness from an fbody because they fit better with fbody accessories and intakes. I bought mine from someone on LS1tech (and a member here come to find out) for $200 shipped and un-cut.
Old Sep 25, 2009 | 11:13 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Are you doing drive by wire or cable? That will play into what you need for a harness as well. but fbody is definitely the way I'd go as well if you're trying to stay as clean as possible with routing without modifying (trucks are nice but will require a bit of trimming if you want them routed nicely, not to mention different plugs for the injectors). Stay away from 98 fbodies though, they are an oddball year when it comes to tuning and not as well supported.
Old Sep 25, 2009 | 11:41 AM
Jim85IROC's Avatar
Good to know, thanks.
I'm sure I'll be going with a cable operated throttle body, so the f-body harness sounds like the way to go. They should be plentiful too.
Old Sep 25, 2009 | 12:33 PM
BlueZee28's Avatar
Ya if you put up a wanted thread in the LS1tech marketplace you will have multiple people respond within days.
Old Sep 25, 2009 | 10:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
definitely some amazing deals to be found over there. got me a set of rebuilt heads for $150/shipped/complete.
hunting a harness myself, but no money to pull the trigger yet...
Old Sep 26, 2009 | 12:07 AM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
I have a harness from an 02 Camaro if you are interested. I was going to use it for my swap, but went with Speartech instead.
Old Sep 26, 2009 | 12:34 PM
Pocket's Avatar
Car: 91 Trans Am
Ill buy the cut harness off of you
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
