smoke coming from valve cover breather
Old Oct 27, 2009 | 03:09 PM
bmfIROC-Z's Avatar
my lt1 has roughly 2500 miles on it and i just noticed smoke(blow by?) coming from my breather on my passengers valve cover under light throttle to wot that almost smells like rich exhaust,is this normal on an lt1?if not what should i do?im in the midst of installing nitrous and i wanna make sure everything is good before i spray it,thanks in advance.
Old Oct 27, 2009 | 03:13 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: smoke coming from valve cover breather
I would say worn valve guide. One thing to think of. When it warms up does it go away? Because If you let your engine sit a while the valve guides get dry and it tends to blow by some oil until it lubs Mine smokes a bit now to b/c it has been sitting.
Old Oct 27, 2009 | 05:30 PM
bmfIROC-Z's Avatar
nah it seems to get a little worse once it warms up,but it does sit alot,so would i have to have new valve guides pressed into the heads?
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
