Additional swap information
#55
Car: Trans-am
Re: Additional swap information
Hi finishing up my lt1 w/ 4l60 e swap. With painless 60502 harness. On my 1989 T A.
Just a couple thing not sure about.
I need to get my speedo working read on a 3gen post that I need to connect VSS out to the green wire on the vss buffer.
Finally the last thing I need to get my torque convertor lock up working
Open to any suggestion.
Thank you Michael
Thank you Michael
#56
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Connect the speedo wire from the PCM to c207 pin k and connect pins c&f on the buffer box together
Tcc is part of the 4L60E wiring, there is nothing extra to connect on that circuit. The p/neutral wire needs to be connected at the c207, but I forget the exact pin
#57
I'm posting this to update the earlier C207 Post from 2009.
1982 C207
PIN Color From / To (Notes)
A Brn ALDL / ECM (AIR control)
B
C Wht Light Driver / ECM
D Tan Oil Pres / Gage (L4)
E Wht/Blk ALDL / ECM (test)
F Pnk/Blk IGN fuse / EGR-ECM
G Pnk/Blk Gge fuse / AC Comp Relay
H Tan/Blk ALDL / TCC-ECM
J
K* Brn ECM / VSS
K* Ppl Brake / TCC ( V6 )
L Org/Blk ECM / P/N switch ( V6 )
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch ( V8 )
P* Ppl Brake / TCC ( V8 )
P* Brn ECM / VSS
1984 C207
B Dk Blue BU Fuse / Back Up Switch ( T5 only )
C Wht/Grn Light Driver / ECM
D Tan Oil Pres / Gauge (L4)
G Lt Green BU switch / Rev Lights ( T5 Only )
J Org ALDL / ECM ( L4)
K Brn ECM / VSS
L Tan/Wht Fuel Relay / Fuel Pump ( L4 )
P Ppl Brake / TCC ( V8 )
R Ppl Crk Fuse / EFI (L4)
1985 C207
A Brn ALDL (pin C) / ECM (AIR control)
B* Dk Blue BU Fuse / Back Up Switch ( V8 T5 )
B* Red ALDL / Fuel Relay ( V6 - TPI )
B* Org/Blk FP FUSE / Fuel Relay ( L4 )
C* Brn/Wht ECM / CE Light ( L4- V6 - TPI )
C* Wht/Grn Light Driver / ECM ( LG4 & L69 )
D* Blk/Org FP/INJ fuse / Fuel Relay ( L69 )
D* Tan/Wht Fuel Relay / Fuel Pump ( V6 )
D* Lt Blue Fuel Relay / Fuel Pump ( TPI )
D* Tan Oil Pr Sensor / Oil Pr Gauge ( L4 )
G* Dk Blue BU Fuse / Back Up Switch ( V8 T5 )
G* Pnk/Blk Gage Fuse / MAF Relay ( V6)
G* Pnk/Blk Gage Fuse / Burn Off Relay ( TPI )
G* Pnk/Blk Gage Fuse / Air Cond Relay ( L4 )
J* Ppl Starter / Fuel Relay ( L69 )
J* Org ALDL / ECM ( L4 - TPI )
K Brn ECM / VSS
L Tan/Wht Fuel Relay / Fuel Pump ( L4 - L69 )
P Ppl Brake / TCC
R Ppl/Wht Crank Fuse / Cold Start-ECM ( V6-L4 )
Plug C221
A Pnk/Blk Inj2 Fuse / Even Fuel Injectors
B Lt Green Back Up Switch / BU Lights ( V6-T5 )
C Brn Fuel Pump-Fan Fuse / Fan Relay ( V6 - TPI )
D Pnk/Blk Inj1 Fuse / Odd Fuel Injectors
E
F Dk Blue Back Up Fuse / Back Up Switch ( V6-T5 )
1986 1987 C207 ( TPI )
B Red ALDL / Fuel Relay ( TPI )
C Brn/Wht ECM / CE Light ( TPI )
D Tan/Wht Fuel Relay / Fuel Pump ( TPI )
G Pnk/Blk Gage Fuse / Burn Off Relay ( TPI )
J Org ALDL / ECM ( TPI )
K Brn ECM / Speed Buffer
L Tan/Wht Fuel Relay / Fuel Pump ( L69 )
P Ppl Brake / TCC
R Ppl/Wht Crank Fuse / Cold Start-ECM ( V6 )
Plug C221
E
1988 C207
** 89 Similar,... Add VATS !?
B* Pnk (Red) INJ1 TBI (TBI)
B* Pnk/Blk (Pink) INJ1 (V6)
B* Pnk/Blk (Black) INJ1 (TPI)
D* Brown (Tan/Wht ) Fan
E Wht/Blk ALDL (pin B) / ECM (test)
F Pnk/Blk IGN fuse / ECM
G* Pnk/Blk (White) INJ2 TBI (TBI)
G* Pnk/Blk (Pnk/Black) INJ2 / (V6)
G* Pnk/Blk (Black) INJ2 (TPI)
H Tan/Blk ALDL / TCC-ECM (auto)
H Tan/Blk ALDL / Upshift (stick)
J* Org ALDL (pin E) / ECM
K Brn/Yellow (brown) ECM / Buffer
L
P
1990 - 1992 C207
A Brown ( TBI )
B* Pnk/Blk INJ1 (V6 / TPI)
D Grey Speed ECM to Cluster (Not with TBI)
F Pnk/Blk ECM fuse / ECM
G* Pink/Blk (white) INJ2 TBI (TBI)
G* Pnk/Blk (INJ2 V6 TPI)
H* Tan/Blk ALDL / TCC-ECM (auto)
H* Tan/Blk ALDL / Upshift (stick)
J Org ALDL (pin E) / ECM
K Brown ECM / Buffer (Only TBI)
L Drk Blue Vats to ECM
M Org Interior Lights
P Red Speed Sensor (Not with TBI)
R Ppl/Wht Crank Fuse / Cold Start-(only TBI)
On several of the diagrams the wire color changed from one side of the plug to the other ( dash harness vs. ECM harness.) In this case I used the DASH harness color ( some Engine harness side wire colors in ( ) ) . I did not take the time to pull out each of the dash harnesses - so It's possble that I missed a wire or 2. If anyone spots a problem just let me know and I'll edit.
Hope this helps !
1982 C207
B
J
K* Brn ECM / VSS
P* Brn ECM / VSS
1984 C207
K Brn ECM / VSS
1985 C207
K Brn ECM / VSS
P Ppl Brake / TCC
Plug C221
E
P Ppl Brake / TCC
Plug C221
E
1988 C207
L
P
1990 - 1992 C207
A Brown ( TBI )
Hope this helps !
#59
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
[QUOTE=Pocket;4341125]Some more diagrams
Engine schematics
LS1
/0411SBC.jpg[/IMG]
I found a difference between this diagram and the wiring schematic on LT1swap.com
TPS wiring pin numbers are different
As shown above:
Black B60
Grey B8
Dark Blue R24
LT1swap.com:
Black B54
Grey B46
Dark Blue R24
Anybody know which one is right?
Engine schematics
LS1
/0411SBC.jpg[/IMG]
As shown above:
Black B60
Grey B8
Dark Blue R24
LT1swap.com:
Black B54
Grey B46
Dark Blue R24
#60
Car: 92 Firebird
Fbody vs truck pinouts change slightly. FWIW, mixing and matching low ref/5v signals or even tying all into a single pin is acceptable to an extent. The red/blue trucks used the exact same PCMs as 99-02 Fbodys
Compare
http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm
http://www.lt1swap.com/99-02_vortec_pcm.htm
http://www.lt1swap.com/2004vortec_pcm.htm
Heres a green/blue GTO pinout that follows the Fbody pinout closely
http://www.lt1swap.com/2004gto_pcm_pinouts.htm
Compare
#61
Pocket THANK YOU so much for all your info I am installing 86 vette MAF engine in my 91 RS TBI car and this is so valuable to me. Is there any other details about that C100 or other things I may need to know not covered in in this thread that you might be aware of between years of this swap. I know it won't be easy But I am retired old guy and have time LOL. Thanks Again Mike
#63
Car: 85 Z28
Engine: 327
So quick question. I been reading through various threads on various site to get a grasp of my wiring before I do my swap. It'll probably be a 5.3 . Anyways car was a tpi. Then carb. Several years ago I believe I ripped out my c207 , as it was the passenger side harness , correct? So do I need to get one from another camaro. Or I make my own harness with new connectors?
#64
Can anyone help me with my current situation. LS1/4L60E swap into my 92 camaro. The motor is from a 04 corvette. I have the stock wire harness. My question is, Can I use the stock harness to get the motor running, or do I need to go out and purchase a stand alone drive by wire harness?
#65
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can use the vette harness. You can either modify it to fut directly to your C100 or route it another way. Lots of ways to do this. I would spend some time reading the wiring stickies before you tear up the vette harness.
