block stamp (wrong block got screwed buying?)
Old Nov 10, 2009 | 08:37 PM
Dustin Fitch's Avatar
Car: 91 Firebird
Engine: 3.1
i bought what should be a lt1 out of a 94 z28. The numbers on the side of the block say 327!!!! when i got it the heads were off and the intake. So i just need to know if i got the shaft and should go busting down doors. The numbers on the rear passenger side i can't really make out but i think they say "10125327" and the driver side has the gm 5.7LG SGI(or T) with F164 under that. Any help would be appreciated
Old Nov 10, 2009 | 08:52 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: block stamp (wrong block got screwed buying?)
www.mortec.com
Good luck.
Old Nov 10, 2009 | 09:49 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
if it says 5.7 then arent you fine?
im fairly sure my lt1 has 327 on it a few places on the block, but it is definitely a 350 5.7...
if it has the motor mounts on it they may have lt1 cast on them.
Old Nov 10, 2009 | 10:09 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
If it has 5.7L, then you are fine. Run the numbers on mortec.com. My LT1 block has the numbers 327 on it.
Old Nov 11, 2009 | 01:37 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
If it says 5.7 then it's a 5.7 (350). 327 is just the last 3 digits of the casting number and it was a coincidence that it said 327, that doesn't mean it is a 327ci.
Old Nov 11, 2009 | 02:31 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Everyone is correct. 327 was the casting number and has nothing to do with the engine size. The L99 (the 4.3 v8 many confuse with the LT1) has like 805 or 508 or something like that cast in the same spot.
Nothing to worry about. You got exactly what you paid for.
Old Nov 11, 2009 | 03:40 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
This is from www.mortec.com
CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES
10125327......350...92-up...2 or 4...Gen.II LT-1, reverse flow cooling
10125327......350...96-up...2 or 4...Gen.II LT-4, reverse flow cooling
Old Nov 11, 2009 | 05:29 PM
Car: 91 Firebird
Engine: 3.1
thank you all, i really didn't want to sound like a dumb @$$. I knew 5.7 is 350 it just kind of made me second guess myself. I always just seem to have that kind of luck, you know without bad luck i would have no luck at all....lol. thanks
Old Nov 11, 2009 | 06:04 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Scared me to when I first bought mine.
Old Nov 11, 2009 | 09:33 PM
kthxbai's Avatar
Car: 1985 Z28
yeah i was worried about it for a good five or so minutes, then realized i was being ridiculous lol
Old Mar 10, 2012 | 11:40 AM
haaappy7456's Avatar
dont mean to contradic all the post, but i also bought a lt1 with a 327 marking on the side and front, thinkin it was a 350. after a few weeks i had it sitting i cleaned it and discover it was the 4.3, how i found out is the only way to know for sure is to look a the back were the bellhousing goes, it will say 5.7 if its a 350 and 4300 for a 4.3. I heard about 588 on the block, but mine does have the 327. just letting you know
Old Mar 13, 2012 | 05:36 PM
1bdbrd's Avatar
Car: 1991 Trans Am
I have a 4.3 just like you are talking about and it does not have a 327 cast into the side of it. If it has 327 on the side it IS a 5.7 lt1. Not the L99. Tear it down and measure the bores if you need to but it isn't a 4.3.
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
