Lets see your third gen LT1 engine bays!
Old Feb 8, 2010 | 08:32 PM
  #51
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Lets see your third gen LT1 engine bays!
None here.. If it was a problem. Compaines like MARCH , etc. wouldnt make kits for the an/braided line conversions.
Old Feb 8, 2010 | 08:34 PM
  #52
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
ive never tried anything of the AN fittings..ill have to check that stuff out
Old Feb 8, 2010 | 08:43 PM
  #53
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.bakerprecision.com/adapt8b.htm
Old Feb 8, 2010 | 08:45 PM
  #54
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i know this sounds dumb,but how do they exactly work?
Old Feb 8, 2010 | 09:02 PM
  #55
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
the adapters screw in the PS box and convert then to AN
Then you put more adapters in your PS pump again to convert to AN.
Its not a cheap conversion. I did it because my Supercharger stuff is AN fitting, my oil drain and feed are AN. Im doing my fuel lines in an. and My custom made radiator and WP will be AN.
I'll get some pic's next time im out working on the car. Im sure you can find pic's on here of others who have done it. Not just a LT1 thing.
Old Feb 8, 2010 | 09:53 PM
  #56
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
W/ the AN fittings you can also use steel or aluminum lines. You would just have to pick up a 37 degree flaring tool, tube sleeves, and tube nuts. I'll eventually redo the fuel lines w/ AN.
Old Feb 12, 2010 | 12:56 PM
  #57
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Originally Posted by Firebat
-Using a alternator from a 92 4.3V6 S10, mounted low, down on the driver's side with a custom-made bracket. Sorry I can't find pics of it.
-All the wires either go through the hole for the a/c wires near the heater core or under the driver's side wheel well. PCM located in the interior. Notice there is no longer the bulkhead connector near the brake booster, it is shaved.
-A/C and LT1 vette fuel rail covers not fully installed yet.
Engine looks very nice. Did you have to do anything different w/ the lower radiator hose? I'm using a 'Vette hose and it is pretty close to the p/s pulley. Also, where did you mount your p/s reservoir?
Old Feb 12, 2010 | 03:15 PM
  #58
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Old setup
Old Feb 12, 2010 | 04:59 PM
  #59
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
oh man i love the strut tower brace! what brand? i like the fuel rail corvette covers too
Old Feb 12, 2010 | 06:06 PM
  #60
Car: 91 Z28
Engine: Lt1
Home made my friend 1.25" chromoly
Old Feb 12, 2010 | 06:19 PM
  #61
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Sweet job w/ that!
Old Feb 13, 2010 | 10:48 PM
  #62
Firebat's Avatar
I'm using a 4th gen radiator so just using 4th gen hoses.
I have the PS res mounted on a homemade bracket, next to the radiator where the battery used to be, on the passenger side. I relocated the battery in an enclosed NHRA-approved box in the trunk. I'm not using the stock hoses, I think I'm using 1-2 foot of hydralic high pressure hose for the large hose that goes from the PS res to the PS pump (could be regular 5/8" or 3/4" heater hose) but the hose just uses hose clamps. Been meaning to take pics of that but just haven't got around to.
Old Feb 19, 2010 | 09:24 PM
  #63
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yeah take some pics when you get a chance!
Trickedouttoy-how about making me one of those strut tower braces!!!??
Old Feb 21, 2010 | 07:51 PM
  #64
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
bump
Old Mar 1, 2010 | 12:14 PM
  #65
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
bump
Old Mar 1, 2010 | 02:13 PM
  #66
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
bump
what's the bump for?
Old Mar 1, 2010 | 09:49 PM
  #67
Pocket's Avatar
Car: 91 Trans Am
He wants to see more engine bays
Old Mar 2, 2010 | 08:50 AM
  #68
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
exactly,thank you jon.
Old Mar 2, 2010 | 11:23 AM
  #69
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Here ya go.
Old Mar 2, 2010 | 11:42 AM
  #70
edpontiac91's Avatar
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
Here is mine from my 1991 Formula L98 350. That's a Hotchkis upper strut tower support along with some SLP bolt-on items such as the runners and the CAI. SORRY, I JUST NOTICED IT WAS FOR LT1 ONLY.
Attached Thumbnails Lets see your third gen LT1 engine bays!-p1010009.jpg   Lets see your third gen LT1 engine bays!-p1010012.jpg   Lets see your third gen LT1 engine bays!-p1010014.jpg
Old Mar 2, 2010 | 12:09 PM
  #71
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
thats ok! i always admire i nice looking thirdgen TPI lol
Rich:build looks great! is that a recent pic?
Old Mar 2, 2010 | 12:19 PM
  #72
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Does that tpi ever look great!
Old Mar 2, 2010 | 12:32 PM
  #73
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
The picture is about a month old. I've added the radiator, hoses, dual electric fans, and some other parts since that picture. I still need to get started on the harness and send out the PCM.
Old Mar 2, 2010 | 01:33 PM
  #74
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Originally Posted by Pocket
Go to NAPA or a hydraulic company and have them make a hose for you. AN fittings and hose wont support the 1200+ psi a PS high pressure line will see
If your still trying to figure out how to do your power steering ^^ this is the way to go, a hydraulic hose company can make you up a hose to whatever length you need with the proper fittings on each end, if you tell them what your doing and even bring them in a fitting that needs to be adapted to they can more than likely make something custom up if need be.
Old Mar 2, 2010 | 01:41 PM
  #75
86LT1's Avatar
Engine: 357 LTx
Heres an old pic from last year when i was finishing up my motor, but you can see where the PS res. is located with a bracket i made up/help from the wiper res. Also I go rid of my coolant res and went with a aftermarket one from jegs. The main hose you have to worry about being made up correctly on the PS is the one going into your steering box. the others can be hose clamped.
Old Mar 2, 2010 | 02:01 PM
  #76
86LT1's Avatar
Engine: 357 LTx
Found a newer one...
Old Mar 2, 2010 | 06:00 PM
  #77
JeremyNYR's Avatar
Car: 1984 Trans Am
I decided to show some pictures of my relocated power steering resevoir also. Pardon the hanging headlight door relays, I was working on them recently and didn't get them mounted yet.
I tucked it as far into the passenger front corner as I could with still being able to remove the top. I used a small section of angle aluminum that I bolted to the unibody under the fender to create a little ledge and then bolted the reservoir to the angle aluminum (painted black). Getting the new generic straight hose to bend in that tight area without pinching off was a bit tough.
Old Mar 2, 2010 | 09:27 PM
  #78
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
nice job..very clean...how exactly does the resivoir tie into the 2 lines? the one line that screws into the pump has to be metal correct? and that goes straight to the steering box?
Old Mar 2, 2010 | 09:46 PM
  #79
Pocket's Avatar
Car: 91 Trans Am
One is feed, other return. Neither are pressurized
The only high pressure line that requires special consideration is the pump to box/rack high pressure line
Old Mar 3, 2010 | 08:36 AM
  #80
JeremyNYR's Avatar
Car: 1984 Trans Am
yeah, like Pocket said the reservoir only has two regular rubber hoses connecting it to the steering pump and neither is high pressure. The pump also has a high pressure and low pressure line attached to the steering box.
Old Mar 5, 2010 | 06:33 PM
  #81
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
so it doesnt matter which line the reservoir ties into?
Old Mar 22, 2010 | 10:41 AM
  #82
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
a little but of an update.Still got alot of work to do.
000_0005-1.jpg?t=1269272455
Old Mar 22, 2010 | 11:27 AM
  #83
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I'm going w/ a Caprice reservoir. Looks like it will be easier to mount.
Old Mar 22, 2010 | 02:33 PM
  #84
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i think thats what i have..that or a roadmaster
Old Mar 22, 2010 | 03:07 PM
  #85
Pocket's Avatar
Car: 91 Trans Am
B-bodys used the same reservoir. Hope you grabbed the AC/PS reservoir bracket too. Cut the AC side off and mount it anywhere
Old Mar 22, 2010 | 04:10 PM
  #86
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yup thats exactly what i did last night then ground it down and shot it with some paint.
0322001658.jpg?t=1269291993
Old May 8, 2010 | 11:11 AM
  #87
carkook's Avatar
Heres mine, cost me less then 1400 for the whole swap.
Old May 8, 2010 | 08:43 PM
  #88
coolmarocrzy's Avatar
Car: 85 Z28
Engine: LS
Axle/Gears: 9inch/3.50 gears
Pic from the old days.
Old May 10, 2010 | 06:01 PM
  #89
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Nice! pretty clean,im kinda regretting painting my intake black now that i have seen all these red ones!
Old May 10, 2010 | 07:46 PM
  #90
Pocket's Avatar
Car: 91 Trans Am
Black looks awesome against the natural finish aluminum
Old May 10, 2010 | 09:00 PM
  #91
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Twin M90s? thats gonna be loud. !!
Old May 11, 2010 | 06:49 PM
  #92
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Great looking project you have going there.
Old May 19, 2010 | 09:53 PM
  #93
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
no leaks at all?
Just seen this reply.
No leaks here form anything.
Old Jun 10, 2010 | 09:00 PM
  #94
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
bump
Old Jun 11, 2010 | 11:38 PM
  #95
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
This pic was right after the swap last year. I need to take some more pics now that it is a little cleaner.
Old Jun 17, 2010 | 09:02 PM
  #96
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Looks very much like mine ill have to get an updated picture on here
Old Oct 17, 2010 | 01:32 PM
  #97
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
How about close up pics of how you guys ran the coolant and heater hoses?
Old Oct 19, 2010 | 11:09 AM
  #98
shoveltrev's Avatar
heres mine in progress,the motors out of a 95 z with just 9k on it, and that was the whole care not just the motor.the pulleys still got black paint on em,crap the pics already loaded in the body section under my zo6 orange iroc
Attached Thumbnails Lets see your third gen LT1 engine bays!-new-pics-031.jpg   Lets see your third gen LT1 engine bays!-new-pics-009.jpg
Old May 31, 2011 | 08:00 PM
  #99
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
lets bring this one back from the dead.. any new pic's people?
Old Jun 4, 2011 | 11:04 AM
  #100
newZman's Avatar
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
This is a cool thread idea, can't wait to have one to add.
