Lets see your third gen LT1 engine bays!
Old Nov 4, 2012 | 06:51 PM
  #151
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Lets see your third gen LT1 engine bays!
That looks great !!
Old Nov 5, 2012 | 11:41 AM
  #152
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
In progress! Going to boost it right away too
More pics to follow once it gets closer to being complete
Attached Thumbnails Lets see your third gen LT1 engine bays!-photo-nov-03-6
Old Nov 5, 2012 | 04:44 PM
  #153
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Could be better
Old Nov 7, 2012 | 10:04 PM
  #154
springer4's Avatar
Car: 1992 Heritage Edition Z28
Transmission: Stock
Axle/Gears: Stock
very Nice, Hopefully mine comes out that clean
Originally Posted by keeslinger31
Could be better
Old Nov 7, 2012 | 10:15 PM
  #155
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
A few old ones, circa 2001/2002 swap in progress pics.
Old Nov 9, 2012 | 07:26 AM
  #156
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Pic is a little crappy, ill post a better one later. Painted the intake to match the hood.
Old Feb 10, 2013 | 04:57 PM
  #157
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
It's later now. More pics!!!
Old Feb 10, 2013 | 05:07 PM
  #158
WolfmanTA's Avatar
Car: 1986 Trans Am
Engine: LB9 TPI V8
Transmission: automatic
Here is my 86 Trans Am! Cheers....
Old Feb 10, 2013 | 05:09 PM
  #159
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Love the bright yellow...
Heres my current project.. in the For sale section also.
Old Feb 10, 2013 | 05:28 PM
  #160
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Great pics......
Old Feb 10, 2013 | 09:54 PM
  #161
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Thanks man!
Old Feb 12, 2013 | 01:34 PM
  #162
jaybdaboat's Avatar
Lt1 Vert with a turbo. I wish
Old Feb 12, 2013 | 02:02 PM
  #163
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
383 LT1 .. It can be yours. Its all in the F/S section.
Old Feb 12, 2013 | 02:47 PM
  #164
jaybdaboat's Avatar
Yea if you gonna trade for my lo5 lol
Old Mar 26, 2013 | 04:45 PM
  #165
jaybdaboat's Avatar
heres my engine bay finally got it back a month and a half later.
gotta replace this 93 alternator then its on the road
Old Mar 28, 2013 | 01:42 AM
  #166
legend71's Avatar
Car: 97 SLP SS, 91 RS, 91 GTA, 92 JY FF
Engine: LT1, VRE 383 LT1, L98, LB9
Transmission: 4L60E, Astro T-5, A4, A4
Axle/Gears: 3.42, 3.70 9Bolt, 3.23, 2.73
Lots of work left to do. Thinking of rewiring...again. This is an old photo. Ill get a better one
Old Mar 28, 2013 | 12:13 PM
  #167
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I didn't see anyone using the Corvette style(92-93) A/C & Alt mounting on top. Is everyone mounting the A/C compressor underneath?
Old Mar 28, 2013 | 04:01 PM
  #168
legend71's Avatar
I just removed it b/c I don't need it where I live. With a stock K-member, you need to cut a notch to mount the a/c underneath in the stock TA/Camaro location
Old Mar 28, 2013 | 06:21 PM
  #169
Strick1's Avatar
What does that notch look like? Does it weaken the K-member?
Old Mar 28, 2013 | 06:50 PM
  #170
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
??? mine is a complete corvette setup. A/C comp. just isnt mounted yet.
and I need to redo my turbo down pipe and put a ac box back in.
Old Mar 29, 2013 | 09:26 AM
  #171
Strick1's Avatar
You are the man I need to talk with. Have you put the Vette brackets on to see if it will fit/work? If so, please take some pictures. The way my 83's A/C hoses run makes me think this would be the best way to go. I have a 92 Vette and the A/C set up seems easy to make work.
Old Mar 29, 2013 | 06:28 PM
  #172
legend71's Avatar
I would have to find the instructions on how to do it. I think I found them on here, but it suggested cutting it or pounding with a hammer. I chose not to both to preserve the K member and b/c I don't need it. I don't know if it would weaken it because the notch looked small. Ill see if I can figure out where I found it.
Old Mar 29, 2013 | 07:10 PM
  #173
Strick1's Avatar
Well down here in South Carolina, A/C is a survival tool in the summer. I do remember someone talking about using a hammer to dent the K-member, but that didn't appeal to me. BUT, if I can't find a Corvette accessary bracket, I may have to do some notching and welding.
Old Mar 29, 2013 | 07:14 PM
  #174
Strick1's Avatar
Could be better
I noticed you have the A/C hooked up, you wouldn't have any photos of what you did to the K-member to allow the compressor to fit?
Old Mar 29, 2013 | 10:58 PM
  #175
legend71's Avatar
Yeah partially jealous, I love Charleston and the rest of the south. The corvette route would probably be better anyway.
Old Apr 1, 2013 | 11:20 AM
  #176
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Added an Electric Water pump; I'll never have to worry about a Failling water pump leaking on my OPTI ever again ! Now I just gotta' find some time to get the Strut Tower Bar installed.
Old Apr 1, 2013 | 05:37 PM
  #177
Strick1's Avatar
Already planned on the Meziere HD elelctric water pump. I have it on my Vette. Love it.
Did you notch your K-member for the A/C compressor?
Old Apr 19, 2013 | 01:28 PM
  #178
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Wow!
You did an amazing job Making an LT1 look like a First gen TPI smallblock
Old Jul 30, 2013 | 07:09 AM
  #179
jaybdaboat's Avatar
Could be better
How did you make that intake shield?
Old Jul 30, 2013 | 07:25 AM
  #180
jaybdaboat's Avatar
Upgraded to a 95 alternator 140 amp instead of 120 (think its the cause of my battery drain)
Fixed my loose kickdown cable issue. It was a universal grabbed some fishing weights.
Replaced the battery
Replaced the transmission
Replaced the oil with 10w30 to fix a lifter tick
A good and efficient cai is next any ideas? I need a really good intake shield.
And to remove the ac completely just don't know what it takes to remove it and keep my heat.
Spark plugs And wires coming this weekend hopefully. Still got look up how to fix my fuseable link and wire up my fan.
Old Jul 30, 2013 | 08:43 AM
  #181
Strick1's Avatar
The LT1 is notorious for lifter ticking. Especially with roller rockers. I wouldn't be too concerned about it. Most guys on the Corvette forum just make their exhaust louder.
Old Jul 30, 2013 | 09:20 PM
  #182
jaybdaboat's Avatar
Well it's fixed now lol.
Old Jan 3, 2024 | 12:36 AM
  #183
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
Originally Posted by BCdawg57
how did you hook up the heater valve in?
Old Jan 3, 2024 | 07:50 AM
  #184
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
If you are talking about that plastic thing on the left side of the photo, I don’t remember. It broke at some point and I just ran the hoses straight to the water pump/radiator and capped any vacuum lines. Works fine.
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
sreZ28
Aug 14, 2015 07:48 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
