Lets see your third gen LT1 engine bays!
Old Nov 21, 2009 | 09:38 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
im doing mine right now and was just curious as to what others did,lets see em!
Old Nov 23, 2009 | 06:15 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: Lets see your third gen LT1 engine bays!
Old Nov 23, 2009 | 09:46 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
that looks b a d a s s nice job..mines still a work in progress and ive done some stuff since this pic
Old Nov 23, 2009 | 10:08 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
don't mind the mess. pulling stock rad. back out for custom made one. and cleaning up all the wiring now.
Info in sig. on combo
Old Nov 23, 2009 | 10:12 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
oh wow...so what am i looking at? an LT1 with a dizzy otherthan the opti?
Old Nov 23, 2009 | 10:19 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
correct. Removed Opti. drilled/droped in a MSD pro billet dizzy. welded up timing cover to loose opti and water pump shaft. Went with an electric pump also.
Using stock 92Z harness and computer. But with the $59 code for boost.
Old Nov 23, 2009 | 10:22 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
now howcome you did that? why wouldnt you have just left the opti? i heard of ppl doing this but i havent heard the reasoning behind it.
Old Nov 23, 2009 | 10:27 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Do a search on all the boards on opti. Its hit or miss if you get a good one to last. So instead of me spending $500 on a MSD opti or converting to a dis. 24x setup for $1500 or so.
I went with what I have and was easy for me to do. I did the intake and cover myself so it wasnt a big deal. I didnt have to integrate or buy a LT1 harness. etc...
Old Nov 23, 2009 | 10:39 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
ohoh i see..good point
Old Nov 23, 2009 | 10:44 PM
BCdawg57's Avatar
What kind of power are you expecting to lay down with that tpi?
Josh swap is looking good. Have you done anything to the engine?
Old Nov 23, 2009 | 11:04 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
whatever it makes it makes.
Its a tiny cam in a 383. So well see. LE3 equivalent heads Comp cam XFI 23x/23x @ .050 .502/.510 , should be 12psi with these pulleys. Im ordering a smaller SC pulley for more boost.
alot of the novi guys are running mid 9's on 12.5 psi. with similar builds.
According to paxton the n2000 will flow enough for 980hp
Old Nov 24, 2009 | 09:12 AM
Drvngstorm05's Avatar
Car: '92 RS
Axle/Gears: 4.11
i'm trying to track down a more recent pic, since that one i had some A/C lines built, i'm also runing an electric water pump now and a delteq ignition system
Old Nov 24, 2009 | 02:54 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Only drawback to going the route that TPI383 did was you still have to burn chips to tune, batch fire injectors vs sequential fire and the tuning capabilities are limited.
I have over 150k on the opti in the car, only trick is keep the vent lines hooked up and it should be fine.
Old Nov 24, 2009 | 02:59 PM
Car: '92 RS
Axle/Gears: 4.11
i've gone through 5 opti's all of them vented, i think its more about luck than keeping them vented and all 5 of those was in about 65k mile duration
Old Nov 24, 2009 | 07:30 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
no draw back at all. go look at what Im running $59 code. people running well over 800+ HP on the setup. You can buy the NVRAM and flash just like a 4th gen setup. while engine is running, etc.
I can still use my auto prom (aup1,etc...) and emulate and make changes on the fly with tunerpro RT. So batch fire vs sequential. personal preff. is what it comes down to.
If anything Id still ditch the opti and go with a delaQ or the 24x setup. http://www.eficonnection.com/24x/default.htm
what I have will get me in the mid 9's So Im fine with it. and cheaper then even replacing 1 opti.
Old Nov 24, 2009 | 09:38 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
All ive done to mine is a mini rebuild.ive torn the heads off and cleaned them til i could eat off of them then replaced head gaskets,intake gaskets oil pump and oil pan gasket and added an air foil to my TB...so it'll be a stocker LT with a full exhaust.i got dynomax headers,a hollowed cat and a hooker 3inch catback.we'll see how that goes then ill upgrade intake and TB when its running good.im def pumped for the spring!
Old Nov 24, 2009 | 10:26 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
not worth buying the edelb. intake over the stock one.
spend your $ on a cam, converter,gears, suspention
Old Nov 25, 2009 | 03:21 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
well im gonna use my stock 3.27's for now and i have a T5 hooked up til it blows then a t56 will replace it...how about some opinions on the LT4 hot cam kit? ive heard from some people not to do it unless i just want agravation.
Old Jan 19, 2010 | 12:27 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
bump
Old Jan 19, 2010 | 02:03 PM
ssean92's Avatar
Car: sold
Old Jan 20, 2010 | 12:24 PM
Car: '92 RS
Axle/Gears: 4.11
i've used my lt4 hotcam from day 1 (about 5 years ago) and i love it. it gives a nice idle, makes decent power, and i don't feel like i sacrificed much in terms of drivability. with shorty headers my car put down 331whp and 327wtq (with 300 lbft of torque as early as 2k rpm) on a mail order tune from bryan at pcmforless
Old Jan 20, 2010 | 01:26 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
thats pretty sick,did you replace cam bearings when you installed the cam?
Old Jan 20, 2010 | 10:13 PM
Car: '92 RS
Axle/Gears: 4.11
i did not, what i did do was use a new timing set (provided with the kit) and roller rockers (also part of the hotcam kit). it is also recommended to replace the water pump gear drive when you replace the timing set
Old Jan 22, 2010 | 06:52 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Klortho,
What flare type (single, double flare) did you put on the end of the steel line where the high pressure hose is attached? I attached a picture w/ a red arrow pointing to it.
Old Jan 29, 2010 | 03:28 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
they aren't very upclose and detailed, but here's mine. I still need to polish the intake, alternator and alternator bracket. I need to replace the rigged stock 4th gen air intake duct too.
Old Jan 29, 2010 | 07:08 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
wow thats a nice bird man! just about the same color as mine too!
For those of you that have your alternator and power steering pump on the drivers side,why is this? my LT1 is out of a 95 car...were the older ones different? or the newer ones? id really like to know.
Old Feb 1, 2010 | 09:35 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
thank you! I'm pretty sure the ones with the alternator on the drivers side are using brackets and accessories (or the whole LT1 assembly) from a corvette.
Old Feb 1, 2010 | 10:14 AM
bmfIROC-Z's Avatar
here's mine:
Attached Thumbnails Lets see your third gen LT1 engine bays!-picture-508.jpg   Lets see your third gen LT1 engine bays!-picture-509.jpg
Old Feb 1, 2010 | 11:16 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Originally Posted by bmfIROC-Z
here's mine:
Did you enlarge the air inlet?
Old Feb 1, 2010 | 12:33 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Nice engine bays. But I'm gonna say a done up tpi on top looks better, but you can't match the ltx's performance. Nice job guys!
Old Feb 1, 2010 | 03:16 PM
Klortho's Avatar
Car: 1987 GTA
Originally Posted by Rich2279
Klortho,
I used my old V6 hardlines, cut the ends off of them and use a single flare with my flaring tool on it, then used clamps made for high pressure FI lines to hold it in place.
Old Feb 1, 2010 | 05:40 PM
bmfIROC-Z's Avatar
yes i did.
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i do agree a TPI looks better as the intake looks b a d a s s but the amount of power coming even from a stock LT1 blows the TPI out of the water
Old Feb 1, 2010 | 05:42 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
how hard was it doing power steering lines? im kinda nervous on doing this...my power steering pump is on the passengers side...any input? what did you do?
Old Feb 1, 2010 | 07:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
NOt the cheap way of doing it but the best way .I used An fittings on braided hoses and adapters in the pump.
Old Feb 1, 2010 | 08:05 PM
Klortho's Avatar
Car: 1987 GTA
I used the stock power steering cooler, had it cut and then had ends fitted onto them for hoses.
Old Feb 1, 2010 | 10:16 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
That is what am doing with mine. I picked up the fuel line pieces from a V6 in the local yard. I also bought fuel injection hose from Advance Auto. Really expensive hose.
Old Feb 2, 2010 | 12:35 AM
bmfIROC-Z's Avatar
i just rebent the 4th gen p/s lines,it was pretty easy.
Old Feb 2, 2010 | 10:15 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I did the same
Old Feb 4, 2010 | 07:18 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
JeremyNYR or BMFIrocz: do you guys both have your power steering pump on the passangers side like mine?
Old Feb 4, 2010 | 11:06 PM
bmfIROC-Z's Avatar
yes my p/s pump is on the passengers side,im pretty sure the only lt1 that came with the p/s pump on the drivers side was the corvette lt1.
Old Feb 6, 2010 | 03:42 PM
  #42
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
thats intersting i didnt know that,i wonder why they did that..
Old Feb 6, 2010 | 07:21 PM
  #43
Firebat's Avatar
-Using a alternator from a 92 4.3V6 S10, mounted low, down on the driver's side with a custom-made bracket. Sorry I can't find pics of it.
-All the wires either go through the hole for the a/c wires near the heater core or under the driver's side wheel well. PCM located in the interior. Notice there is no longer the bulkhead connector near the brake booster, it is shaved.
-A/C and LT1 vette fuel rail covers not fully installed yet.
Old Feb 6, 2010 | 08:06 PM
  #44
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
pretty sick man nice job! id like to find the corvette setup to relocate my PS and the alternator
Old Feb 8, 2010 | 10:58 AM
  #45
JeremyNYR's Avatar
Car: 1984 Trans Am
yes, i have the f-body setup with the pump on the passenger side. I'm guessing the vette can't fit an f-body setup due to hood clearance. now that I think about it though, I'm not sure why the f-body didn't utilize the same accessory setup as the vette since the vette setup must've been developed first.
Old Feb 8, 2010 | 07:00 PM
  #46
Firebat's Avatar
I'll also reply to this.
I tried a new power steering line (high pressure side) from a 4th gen and it looked impossible to get it to work because it was way too short. Maybe O'Reilly's ordered me the wrong part? I used a PS line from a '95 caprice LT1 and bent it to fit. However, I plan on buying a custom braided stainless steel line because even the bent-to-fit line is still somewhat a pain to work with. I route my MSD plugwires inbetween a gap thats between the bracket and the block, just so happens that the PS line is right there in the way too. And always have a little bit of a challenge getting the threads started on that fitting for the bent line.
Old Feb 8, 2010 | 07:40 PM
  #47
Pocket's Avatar
Car: 91 Trans Am
Go to NAPA or a hydraulic company and have them make a hose for you. AN fittings and hose wont support the 1200+ psi a PS high pressure line will see
Old Feb 8, 2010 | 08:00 PM
  #48
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yeah ive had this trouble in the past too..works great til a turn the wheel then they pop off...(talking about the rubber return line)
Old Feb 8, 2010 | 08:26 PM
  #49
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Who says? If you Use the right line (high pressure fabric braided hose or teflon lined steel braided hose) and the right fitting you have no problem. I've had to do countless an/mil spec fitting and hose in aircraft. They must be pressure test to well over 1200psi before we can install them.
On my lt1 swap I used teflon lined braided hose and the 16mm and 14mm to An adapter fitting for the ps box. AN ftting in my PS pump, etc....
Old Feb 8, 2010 | 08:30 PM
  #50
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
no leaks at all?
