LT1 parts list
Old Dec 20, 2009 | 08:26 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
LT1 parts list
I'm planing on swapping a LT1 into my 1991 RS (305 TBI). Am I missing any parts on my parts list?
Lt1 engine
Wiring harness
ECM
A/c relocation or frame notch.
PS lines
Fuel lines
Fuel pump
Intake ducting
1.625" or larger Headers
other parts I may need...
Motor mounts
hoses
flywheel
Items added to list:
TPI throttle cable.
T56 Swap cross-member
Clutch hydraulics
Clutch assembly
Thanks-
Eric
Old Dec 21, 2009 | 04:48 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 parts list
Looks like a start there will be some nickel and dime stuff always is. You need 1 5/8 or bigger for the headders.
Old Dec 21, 2009 | 10:32 AM
ericjon262's Avatar
Re: LT1 parts list
1.625" and 1 5/8" are the same thing.
Old Dec 21, 2009 | 11:20 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 parts list
TPI throttle cable
What trans will be behind it?
Old Dec 21, 2009 | 11:37 AM
ericjon262's Avatar
Re: LT1 parts list
I'm eyeing a LT1 T-56 parts car so most likely a T56.
Old Dec 27, 2009 | 02:23 PM
ericjon262's Avatar
Re: LT1 parts list
Originally Posted by Pocket
TPI throttle cable
Would a throttle cable from the LT1 donor vehicle work (1994 Trans Am)
Thanks-
Eric
Old Dec 27, 2009 | 03:43 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 parts list
It will if you bend the gas pedal, it's easiest to get one from a '90-'92 TPI car.
Old Dec 27, 2009 | 04:35 PM
ericjon262's Avatar
Re: LT1 parts list
I plan to use the 4th gen pedals would I still have to bend the gas pedal? also, how much would it have to be bent? an inch, 6 inches?
Thanks for the help-
Eric
Old Dec 27, 2009 | 04:44 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 parts list
1/2-1" just enough to achieve WOT
Using the 3rd gen cable, a nub on the LT1 bracket must be filed down
Using the 4th gen calbe, a washer must be installed on the firewall and the pedal arm bent slightly
Old Dec 27, 2009 | 05:17 PM
ericjon262's Avatar
Re: LT1 parts list
Thanks!
Old Dec 27, 2009 | 06:37 PM
Klortho's Avatar
Car: 1987 GTA
Re: LT1 parts list
I went to chevy and got a cable for a '91 Z28 (cost me like 20 bucks), also using 4th gen pedals and it fit just perfect, no bending or anything.
Old Dec 27, 2009 | 06:44 PM
ericjon262's Avatar
Re: LT1 parts list
only $20, I'll have to look into that, any chance you have a part number?
Thanks-
Eric
midge54
Jan 29, 2017 07:00 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
