LT4?
Old Jan 3, 2010 | 02:41 PM
greenjeens's Avatar
LT4?
I dont know if this is the right place to ask this question but here it goes. I just purchased an 96 LT4 block. It's at the machine shop now getting mag'd and hot tanked. Thanks to the low tension rings I can stick with the stock bore after 90k miles. Here is the question, I have a 95 Z with LT1 and a bad block. Can I put all the stuff from the 95 Z28 onto the LT4 block? I mean everything From pan to intake. pistons, crank, accessories, intake, etc, etc?
Old Jan 3, 2010 | 05:01 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: LT4?
If the LT4 has the heads still you'll want to keep those(or sell them to me dirt cheap!) and the LT1 intake would have to be port matched to the LT4 heads, but it all should bolt up the same
Old Jan 3, 2010 | 07:04 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT4?
Yea the only difference was the LT4 had higher flowing heads,intake, little better cam and factory 1.6 rr.
Old Jan 3, 2010 | 07:15 PM
greenjeens's Avatar
Re: LT4?
The guy I bought it from said he was planning on keeping the heads and intake and injectors, but I could probably snag them from him for the right price. That would be nice. The block had 90k on it, and for some reason it ate the cam bearing on the 4th cam bearing journal, didn't spin in the bore though, so I paid 200 for the block and mains. Never heard of that happening, eating a cam bearing. I figure worse case I would have to have the cam bearing bores honed, I seen the cam, and it had heat marks on it, and had looked like metal chunks had carved a groove into that journal. The motor ultimately lost oil pressure. I might have to give him a call back and see what he wants for the whole top end. I was also going to get the crank rods and pistons, for 75 bills, hopefully he has the damper to, I think thats different balance then the Lt1 damper. A little heavier. Good to know that I won't have to source out the front accessory drives and such for corvette, and wont have a problem bolting the Z28 stuff on.
Old Jan 3, 2010 | 07:43 PM
ericjon262's Avatar
Re: LT4?
here's a good reference site for LT1/LT4 info
http://www.grandsportregistry.com/lt1vslt4.htm
Old Jan 3, 2010 | 08:38 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT4?
blah, nm....
tommy z-28
Oct 6, 2015 10:58 PM
thekurlyone
Sep 30, 2015 12:54 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
ssgt usaf
Sep 21, 2015 12:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
