Question about 6.0L
Old Jan 5, 2010 | 07:59 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Question about 6.0L
I have access to a 6.0L from an 04 Cadillac Escalade for $900. I'm wondering first of all, is that a good deal and is there anything that i need to look for in particular.Thanks.
Old Jan 5, 2010 | 08:22 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Question about 6.0L
That is the LQ9, it is the best 6.0 you can get really, you can mill the stock heads and get 10 to 1 compression if you like, or leave it 10 to 1, but it is a great engine.
Old Jan 6, 2010 | 05:36 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
unless there's something majorly wrong, thats a good deal on a nice engine.
Old Jan 6, 2010 | 05:40 PM
one92rs's Avatar
Car: SOLD!!!!!
from what i understand not all 6.0's were the lq9's. as i understand only the ext models were lq9's. if you look it up only the ext models had the 345hp engines.
Old Jan 7, 2010 | 01:16 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I think all Escalades had the LQ9, i could be wrong. The EXT must be the chevy truck.
Old Jan 7, 2010 | 05:03 PM
one92rs's Avatar
Car: SOLD!!!!!
no sir the ext cadillac escalade had the lq9 only. all others were regular lq4 or 5.3
Old Jan 7, 2010 | 05:24 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
That's a great engine at a great price.
Old Jan 7, 2010 | 10:35 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
There's nothing wrong with it. It was running fine when taken out and has been sitting at my uncle's shop for a couple of months. I'm pretty excited either way because I'm finally on my way to removing the carb'd 305. Now I need to find a complete LS1/6 intake,f-body accessories and oilpan setup and i'll be good to go. I can't wait. Any tips and assistance will be accepted.
Old Jan 9, 2010 | 01:12 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
The casting number is easily seen on the heads. If its says 317 its the good engine. 317 heads are basically LS6 Z06 Corvette ports with larger combustion chambers so they can be run on regular grade fuel
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
