keeping vats?
Old Jan 24, 2010 | 09:45 PM
rock861261's Avatar
keeping vats?
i have been searching and searching and cant find if i can keep my vats 91 camaro wih a ls1 swap or how? any ideas
Old Jan 25, 2010 | 04:58 PM
Pocket's Avatar
Car: 91 Trans Am
Re: keeping vats?
Youll have two different VATS systems to deal with. The LS1 VATS must be disabled. You would have to swap nearly everything from the donor car over to make this function
3rd gen VATS is iffy. The fuel disable and injector kill functions will be gone as they were governed by the VATS module to the ECM and the old ECM is history. The only remaining function is the starter enable relay behind the drivers kick panel. Some swaps are A-ok with leaving this put and the original key. Some are not and the relay must be bypassed. I wish I could tell you which was the case, but youll just have to try it
How to bypass is covered in the additional swap info thread
To maintain some level of security various owner switches can be installed and hidden to disable a number of functions to prevent the car from cranking. You're on your own there
Heres a good one
https://www.thirdgen.org/forums/elec...mobiliser.html
junior419
Apr 7, 2025 11:35 AM
gta892000
Aug 11, 2019 11:16 AM
Racerx974
Sep 19, 2015 10:16 AM
Winchester1094
Sep 15, 2015 09:48 AM
studebaker60
Sep 7, 2015 12:36 PM
