LSX427sc w/ac from a 3rd gen
Old Feb 23, 2010 | 04:04 PM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Hello guys,
Well I have another question...I want to run the third gen AC...I will be using the AC system from the 3rd gen but will get the adapter hoses for
the 4th gen/vette compressor...
The connector is the same I believe, compressor is being shipped with the motor...aaahhh.
I noticed it still had a cycle switch, fan switch, and hi pressure I believe!
This deal is on a relay and then slips in the firewall plug....the wire is brown and come from the alternator plug.. Will I beable to use any of this or will it have to be rewired...the computer is a M90 deal...
I had a ramjet350 with a stand alone computer in it(OBD 1) and the AC worked fine...so it did work with the factory and ramjet set-up
BE KOOL rad and 2 fan set-up is what I ran with the Ram..Works get..
So how can this work..thanks
Old Feb 23, 2010 | 07:04 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX427sc w/ac from a 3rd gen
The AC system is independent of the ECM/PCM control. Any computer relation is to bump up the idle to prevent stalling
To use the 3rd gen stuff, just make new lines to go from the condensor and compressor. You will have to use the 4th gen compressor clutch connector and join the wires in the pressure switch at the rear of the old compressor. The 4th gen unit has no provisons for it
Got a link to this M90 control? Ive heard a good bit of questions regarding it and know nothing about it
Old Feb 23, 2010 | 11:19 PM
Pocket....
the motor and all will be delievered today..I noticed that
on one of the links you gave me that John Spear was on the LS1
tech line..its his harness I believe.
Give me a few and I will see if I get good info on this
M90 computer set-up..
So the AC is hooked up in series with a low voltage power..
Or keep the wires hooked up...So the Brown wire from the plug on the
alternator plug can be cut away frfom the wire block by the brake booster..
Because it will get power from the AC controller..right
Old Feb 24, 2010 | 09:03 AM
Pocket's Avatar
Car: 91 Trans Am
The AC circuit has absolutely nothing to do with the 3rd gen alt wiring
It goes like this. Fully independent of the computer, with one reference when it is engaged
http://www.austinthirdgen.org/mkport...F_and_vin8.jpg
V6 or TBI carbs will have other switches to bypass in order for this to work. They are mainly fail safes so you dont overload the stock engine and stall out
If you're using a speartech harness, why bother with a different PCM? Use the LSx unit and skip all these hassles of wiring some like a carb, some like LSx, some like SBC etc
Old Feb 24, 2010 | 09:30 AM
Hey pocket,
Sorry for all the hassling question. I was just trying to cover my bases but
the easiest thing to do is wait til it comes in today or morrow.
I thank you for the info thou...great help.. Cause I had already modified the harness for when I had the RamJet w/OBD 1
Also on the invoice sent by e-mail it says M90 computer with O2 set-up, so it may not be one of Spears...
thanks for the help..probably be on here soon...hopefully with pics
ex-x-fire
Jan 12, 2024 01:58 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
