anyone run into this problem?
Old Mar 3, 2010 | 12:38 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
so i installed my t56 tonight behind my ls1 and the shifter doesnt align with the shifter hole. the shifter seems to be sitting an inch or two to far back. heres a pic. i need suggestions for a fix please, thanks.
Old Mar 3, 2010 | 12:48 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: anyone run into this problem?
Looks to me like the only fix would be, either cut the hole bigger, or move the engine/trans forward (custom motor mounts)
Old Mar 3, 2010 | 12:55 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
yeah thats what i was thinking to cut the hole bigger. Im using a spohn lsx swap k member so im not sure if that is causing it. its sux because now my shifter boot wont be big enough
Old Mar 3, 2010 | 02:34 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Just cut it, thats what i did with my LT1 T56 behind my 305 car and it is what i and you will have to do with the LS1 swap.
GL, sorry i didnt take pics.
Old Mar 3, 2010 | 06:44 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Its well documented that the T56 shifter sits about an 1-2" back than the t5 shifter.
http://www.techcessive.com/tech/t56/t56.php
If you use the T56 lower boot, then you'll be fine.
Another trick is to place a piece of metal across the front, and then use that to mount the boot with some self tapping screws.
Don't worry, the shifter will still be placed right in the middle of the console, and no one will ever know
Old Mar 3, 2010 | 09:56 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
thanks everyone for helping me out
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sherpajames
Aug 7, 2015 06:56 PM
