LS2 Power Steering Line
Old Mar 8, 2010 | 07:15 PM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
quick question for those of you that have completed the LSX conversion: I have an LS2 with GTO accessories and I need a pressure side power steering line. Reusing the stock line is not an option (I don't even know if it would fit the GTO pump anyway) since I destroyed it in a fit of rage. Should I get the LS2 hose and then change the steering box end? Thanks for your help.
-Brandon
Old Mar 8, 2010 | 07:41 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: LS2 Power Steering Line
Is the pump in the same location as an Fbody pump? If it is, buy an fbody pressure side line from RockAuto.com, I think its about $20 and fits great. It is what I am using.
Old Mar 8, 2010 | 10:15 PM
Car: 92 Camaro RS
Engine: LS2
Thanks man, I'll give that a go
Old Mar 9, 2010 | 10:49 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
When i did my swap, i opted to run a russel teflon braided feed.
For the pump you need a M16x1.5 oring to 6an adapter, and then you need a M18x1.5oring to -6an for the gear box.
Then i ran 2 90* teflon fittings & bought 3' of line. i think it was around $60, and beyond working flawlessly, they looked friggen sweet!!
Liked them enough i made a braided feed for my 4th gen also
I ran a cooler in my return, so thats why my power steering runs to the front from the outlet.
Old Mar 9, 2010 | 05:19 PM
Car: 92 Camaro RS
Engine: LS2
thanks for the info sheldon
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
Thirim
Aug 13, 2015 03:09 PM
