Where to buy tuned PCM
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I am looking to buy a pretuned PCM for my LS1 swap, I don't feel like buying a PCM then shipping it to a tuner to have it edited, I'd rather just buy one all ready to go, plug and play. Anyone know where I can get one that is tuned for an LS1 swap or does anyone here tune them?
Actually I just found some on eBay from a company called Spare ECM. What options do I need to change in the PCM for this swap anyways? Here is their list:
- 1999-2000 LS1 Operating System Installed
- Eliminate VATS (vehicle anti-theft system)
- Rear O2 Sensors Delete
- Fan 1 Temperature On and Off Changed
- Fan 2 Temperature On and Off Changed
- Axle Ratio Changed
- Tire Size Changed
- Top MPH Raised
- RPM Limit Raised
- Diagnostic Trouble Codes Delete
- A/C Deleted
- EGR Deleted
- Air Pump Deleted
- Fuel Tank Pressure Sensors Delete
- Disable Torque Management (automatic)
- Tire Size Changed
- Top MPH Raised
- RPM Limit Raised
- A/C Deleted
- EGR Deleted
- Air Pump Deleted
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: Where to buy tuned PCM
I highly recommend spare ecm, they are a very good company and they know their stuff. I bought my pcm from them
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
i recommend spare ecm from ebay also they do a great job. just search their name on ebay then tell them how you want it tuned
Awesome, sounds like Spare ECM it is
Thanks guys.
Thanks guys. Joined: Sep 2007
Engine: LSx 5.3
No problem, when I get home I'll send you the list of DTC's I had deleted. BTW are you keeping emissions or no?
I have to pass emissions but I am deleting EGR and AIR.
BumpaD82
Feb 26, 2016 02:57 PM
