which walbro fuel pump?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In searching for Walbro fuel pumps, I found a bunch of in-tank pumps that are 255lb/hr pumps.
GSS342, GSL392, GSS340, GSS341, and GCA758-2. The last one is the one specified for our cars, but it comes with a bunch of other crap that I don't think I need. I've seen somebody here mention that the GSS340 is what came with their Hawks kit.
So... which pump? I want a stock-type in-tank replacement that can support high horsepower. It also needs to be able to provide the LS1's 58lbs.
Engine: Cammed 6.0L LSX
Re: which walbro fuel pump?
I wish I could tell you the exact part number of my pump, but I do know that all I did was search on summit's site for a 255 Walbro pump that was stock style, in tank, and it came up on the search just fine.
Transmission: 4L80E/4L80E
The GCA758-2 is what I was planning on getting for Berlinetta #2. Not sure how much HP I'll end up making, but should be in the 400+ range.
From what I can see, the GCA758-2 is just one of the other models, plus a bunch of other crap that has no use, and it's $25-35 more.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm running the same one that I have in my Mustang, wish I could remember the part number, but it works just fine for me....it came with a plug to splice into the original wiring in the tank and haven't had any problems at all.
Yeah, that would be the "other crap". I can live without it. Fuel hose is plentiful and cheap, I can make my own adapter harness, and if I can't source a new strainer for a couple bucks, I'll reuse the one in the car... it's only been a couple thousand miles since I replaced the fuel pump anyway.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
make sure its truly submersible. I put a regular fuel hose in my tank on the sled, and it lasted less than a year before it got mushy (110 didnt help either i suppose)
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I am using the GSS340, but then again I havent fired my car up yet to make 100% sure it's right. It was a direct fit though.
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
