no alternator output
Old Apr 12, 2010 | 12:27 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
verified that my alternator is not putting out..i was wondering if anybody has a wiring diagram for a 98 camaro alternator or anything that could help..i have the big black wire goin form the alternator back to the battery and the signal wire is hooked up...question...is the signal wire a positive wire, or is it grounded through the computer?? I looked thru the stickies but couldnt find anything..thanks guys
Old Apr 12, 2010 | 01:48 PM
Pocket's Avatar
Car: 91 Trans Am
Re: no alternator output
98's do not use the PCM to control the alt. Just a dummy light. For a swap, you must either use a light or resistor to know the voltage down on the signal wire to prevent the alt from burning up
http://www.ls1tech.com/forums/conver...aq-thread.html
See if you're getting any voltage on the alt connector with the IGN on. If you are and it's less than 12v then have the alt tested at a parts store. If its 12v or higher, add a light or resistor inline. The alt most likely will be burned up
No voltage on the wire means its not connected properly. Recheck your wiring
apie2546
Oct 16, 2016 02:24 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
6998poncho
Sep 25, 2015 02:56 PM
