I should not be left unsupervised
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: I should not be left unsupervised
Glad to see you're back on the forum Pocket
This is some badass sheit!!
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Ive never seen that intake before, glad to see someone changing it up alittle bit. Looks sweet!
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Sorry to hear about the old setup. That was truly impressive and it was a great thread t follow.
This new intake is mind blowing. I am forced induction freak and I Have never seen this company? Nice find. Looks like it should be a trip. We're you dig this thing up at are there any others for a good deal :-)
Car: 1992 B4C 1LE
What sickness do I have that I can visualize a turbo on the pass-side feeding into a FMIC that exits out and feeds into the driver-side turned throttle-body?
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
That supercharger is wild looking! It looks very similar to an LSA engine setup. And BTW, didn't you have a 6.0 in your car?? I noticed the piston was dished, and I believe that dished pistons came in only 5.3's while 4.8's and 6.0's had flat tops. Anyways, looking forward to seeing this thing complete. Going to be one of a kind in a 3rd gen.
Car: 91 Trans Am
I have a LQ4 in the car. LQ4's are dished, LQ9's flat tops. The LS3 heads require a 4" bore minimum to clear the huge intake valves. Had to run LS3 heads because the blower has rectangle ports. Snowball effect...
LSA/LS9's and that oddball SC Northstar all use the inverted blower with the intercooler on top. Pretty sweet setup on each. IIRC Saleen did the first heavily marketed setup like that for Fords, but there may be an earlier version
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I think the heat is going to be turned up a bit for you pocket.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
alternator is going to go in the stock fbody location it appears.
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I think it's custom, I've never seen a GM PS pulley like that.
Engine: 7.0L
it looks like a larger rib count. but from what i've gathered, a lot pumps share the same shank size. i'm just trying to find one that's open so i can easily get to the mounting bolts without having to take the pulley off. just need to figure out belt depth, etc.
Car: 91 Trans Am
8 rib system
PS pulley, Alt pulley, tensioner pulley, and two idlers on the pass side are from the Techco kit. Powerbond makes 8 rib stock replacement balancers, so I got one of those for a corvette spacing. Large idler on the drivers side is a LS9 part I got off ebay
Accessory bracket is custom too, made my own to reduce costs using junkyard parts. PS pump is from a early 2000's Northstar, alt is off a S10
Waterpump is a LSA crate take-off from ebay. Wanted the drivers side water outlet to avoid the belt
Bits and pieces of everything for sure
Car: 1986 Trans am
Engine: 5.3 LM7
Wouldnt be a true hotrod if it never broke. Wasnt a hard fix in the end. Found the Techco on ebay. Had never heard of them before I stumbled across it. Was too cool to pass up
As far as the LS3 heads, you won't mind the cost of them as soon as you see the HP you put down haha. Gonna be a monster.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Wowwwwww... I've gotta say Pocket, you are definitely kind of
- but in the most awesome way!!
This thread (by itself) was totally worth getting back onto TGO for!!
Definitely going to have to keep up on what you're doing...
Definitely going to have to keep up on what you're doing... Thread Starter
Car: 91 Trans Am
Didnt make a whole lot of progress tonite and had a decent setback
Pulled the HVAC box from a parts car and threw in there. Fits just fine, still have room for the coils and wires
Spohn K-member strikes again. No way the AC compressor will fit. Cant even get the bracket in there
Most of the interference is the K-member "brace" (use that term loosely). Rest is from the excessively huge A-arm box
That was a pretty big downer since I have the harness wired for AC and had planned for a more refined cruiser on this build. I guess T-top AC will have to do. I started rolling ideas around to get a compressor mounted some way either by crank hub mounted mandrel drive up front or a top mounted compressor on a custom bracket. Since Ive had to reinvent the wheel every step of the way for the last several engines, Id said screw it and threw the old AC delete box back on
Since the condenser isnt going up front I decided to throw the heat exchanger in to see how well it fits. Fills up the space nicely
Lastly, I started to plan out my fuel system and intake box. Since the drivers fuel rail hits the wiper motor already, Ill have to get creative. Anyone know of a low profile wiper that can fit with a mod or two? I also started planning the intake box over the drivers valve cover to utilize the stock power bulge. With the battery on one side of the engine bay and the intercooler tank on the other, where to run the intake is getting tricky
Just another day
Just another day
Car: 91' RS
Dang that blows :/
Would a stock wiper motor work just clocked in a different position and making some new holes to bolt it down?
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
M90 will support a 5.7l No friggin way!!!!! supercharged LT1 is within reach!
BlueZee28, If I know the look of my steel, which I normally do! I believe that the flanges are chrome plated mild steel, the dead give away "aside from the rust" is the "shinny" torch or punch ribs. the pictures are giving me conflicting information, as to whether it was cut or punched. if it was punched, It is likely not S/S. S/S is crazzy hard to punch. just my observation fron the "chair" LOL however the tubes do look S/S.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Car: 91 Trans Am
Car: 91 Trans Am
Spent a little time in the garage again
Finished up the fill bottle (pass rail) and added the fittings. Since it was 1/8" wall tubing, tapping would be problematic at best, so i planned to use aircraft adhesive from work. Who would have guessed, but the particular type of PVC used on the fittings was resistant to the glue. I had to substitute JB weld and it didnt cure fully in time to sand and paint at work before christmas break. Oh well. I did however continue to fit the hoses, have to keep them tidy
Fabbed an aluminum bracket for the intercooler pump at work. Mounted it to the front impact bar directly in front of the heat exchanger
Since the drivers battery tray is occupied by the IC tank, I plan to build a box using a rectangular filter to draw air from the powerbulge opening. Although I would REALLY love to keep the MAF, space is extremely limited, so this might be SD strictly for packaging purposes
Heres a good pic of the 2 gal IC tank and custom alum throttle cable bracket
I installed the trans for a mock-up and jacked it up as high as it would go. Wiper motor still doesnt clear. Started rolling ideas around and noticed the engine was sitting crooked. Seems approx 1/2" lower on the pass side. Minor issue at this point, but I started considering changing the engine location since Ill be rebuilding one mount already. Currently its 1" setback using the hawks (crooked) mounts, if I built new ones at 0" setback, the wiper will definitely clear and the AC compressor has a good chance of clearing the K-member once the chassis "brace" is lopped off. Win-win at a slight loss of weight distribution
On the other hand, shifter location will be moved, cutting a new hole either way. Driveshaft length will also change, but a custom DS is required with the 8.8 anyways
Think moving the engine will be the easiest solution to several major problems
Yes and no. It will give you a nice boost in the low end, but will drop off quite a bit up top. On my 5.3L is was about maxed out. If you're building it yourself and dont really care about crazy high numbers, go for it. If you plan to break 400hp, Id pick a different blower
all I am wanting is low end, max 5500 0r 6k love the torque curve on the 5.3. I am a torque junkie LOL. I have put 500ci Cad's in 3/4 ton GM trucks just for the launch NUT!!!
Those were the Chinese 1 5/8" headers that hawks switched out for the 1 3/4"s in the GP a few years back stepping on quite a few toes, including mine. I compared them to the ebay $200 5th gen camaro headers I was attempting to run and they're identical in manufacture. Does it make any difference at all if the flange is mild vs the SS tubes? Not at all. Small tubes and restrictive collector will make the difference. Would I run them on a mild 5.3/5.7? Sure, blown 6.0? No
Car: 91 Trans Am
Flange is not a factor as long as the S/S tube goes all the way to the head inside of the flange
Car: 91 Trans Am
Got a bit more done tonite before the cold got the better of me
Finished the offset motor mounts and put them in. I tweaked the through hole on the pass side a bit so the engine sits level now
Three bits of good news: wiper motor clear now, will still have to take it off to put a clutch in
Alt output stud has ample clearance, dont have to notch the K-member anymore
Truck AC compressor clears, so having AC is back on the table
One downer, the truck AC compressor doesnt look like a possible candidate for the system. I can build the bracket and mount it fine, just no one that Ive found offers a fitting to attach to custom lines. Maybe Ill find a corvette bracket/compressor cheap and simplify the make-everything approach Ive had so far. Going to draw one up and see if I can pull a favor to have one made
Pocket - I know you probably have your reasons for the Spohn crossmember, but if you had your heart set on AC, how about going back to a stock crossmember and notching it for the compressor?
Can you make your oil pan work with a stock crossmember?
Car: 91 Trans Am
The issues this time are from Spohn's "brace" mounts
These in particular
For a vanilla LSx swap on a stock K-member not using AC, both clear. Using Spohn's K-member, the drivers side has to be lopped off to clear the alt output stud due to his jig being about 2" off. I wasnt happy taking a cutoff wheel to a brand new K-member the day i installed it but such is life. With my new accessory layout, the alt was moved rearward slightly with the corvette spacing so again the alt output stud contacted the stump of a trimmed brace leg. This has nothing to do with Spohn as theres no way he could have foreseen my accessory setup, it was merely me lamenting about having to chop on it further. For the AC on the pass side, that mount is directly in the way, so it too has to get lopped off as well
Next my issue with calling them braces at all are the fact that he uses a pair of 3/16 x 1.5" straps to secure them to the K-member and bolts the stock stamped braces directly to it. These flimsy straps arent bracing anything, you can bow them with your bare hands
Now with the braces out of the way and the engine moved up, clearances are looking good. Just wondering why Spohn even offers the braces at all since they dont fit much of anything or function at all like they should
You can see the two brace mounts here and where they mount to the stock K-member in the rear
Eventually I will get around to building my own K-member. I cant see going back to stock helping anything
These in particular
Car: 91' RS
I had issues with the braces too, with fbody accessories. I had to make a small notch on one of the braces for the alternator. Maybe sphons jig is off.
Car: 1986 Trans am
Engine: 5.3 LM7
I went BMR on the K member and had no issues with fitment whatsoever. Heard a lot of negative stuff on the spohn one so I stayed away from it. Looking good though pocket!
Car: 91 Trans Am
With a small notch to the A-arm pocket, the AC compressor slid right in. Now to order new parts and have a custom line made
Had a little time left and decided it would be a good idea to mod the spindle for the CTS-V brakes Ive had laying around for over a year
What an upgrade
Eventually Ill gather the courage to cut a hole in the firewall for the clutch master and chop the trans tunnel for the shifter
Got two 8.8's to modify in the near future
What an upgrade
Car: 1992 B4C 1LE
Car: 91 Trans Am
Thought I covered how its done on pg 10-11
Ranger/crown vic 28 spline axle, chop the tubes off a few inches from the diff
Chop tubes off 10 bolt, light grinding so they slide in
Weld tubes, install 10 bolt axle shafts
Build TA mount
Order custom DS
Done
Anyways, this time Im trying a different approach
Explorer 31 spline axles. Left side is the same as 3rd gen length while right side is too short. Grabbed an extra LH axle shaft and will lengthen the RH tube approx 3"
Fab and weld on mounts
Fab TA mount
Redrill axle shafts and brake disks from ford 4.5 to GM 4.75 pattern
Order spacers to use my corvette wheels or 3rd gen wheels
Order custom DS
Done
The latter was due to not being able to find 10 bolt axles to cut up cheap enough, LS1 disk brakes being expensive and not needing to buy custom axles
Most 8.8 builds end up around $1000 with all the extras people buy. Id like to begin with most of that stuff. This way I find a lower mileage diff with the gearing I want and decent disk brakes all in one shot. Using stock axles saves a bundle and being the correct 3rd gen width is a huge plus
Down side is I must fab my own mounts and lengthen a tube
Build TA mount
Order custom DS
Done
Fab TA mount
Order custom DS
Done
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
oh, and its only $17 from Autozone
Car: 91 Trans Am
Cut the hole in the floor for the shifter and drilled the firewall for the master
Last job of the day was mounting the pedals, hardest part of the whole endeavor so far
Car: 1992 B4C 1LE
Sorry Pocket, I went back to those pages and saw the rear and felt silly when I remembered it all.
Engine: 7.0L
Car: 91 Trans Am
Figured I should update this thread as this setup is nearing completion. Dont mind the shaky hands
Engine bay is about done. Need to button up the fuel system and AC. Funny thing about AC, cost me $100 to get rid of it with the delete box and nearly $500 to put it back in
New 8.8 is installed. Explorer 31sp axle, extended 3" on pass side, Fbody brackets welded on, Ford brakes, ford to chevy adapters for the thin spoke wheels. TA mount is a bit different. I used a single piece of angle vs the twin tubes, same basic design though
Mounts and trans are hammered out. Redesigned my mounts from scratch similar to the spohn solids for LS1 4th gens after going through about 5 revisions. Only way to correct the spohn K-member tilt and move the engine forward 1" while retaining as much room as possible. Nailed it, as all 8 mount bolts can be hit with a swivel socket from below
Spohn's
Mine
1.5" x 1/4" crossmember
Stock vs my preferred mount. Lots more meat and my last monster with a 4L80E couldnt tear it up
Installed. Notice the pass header is MUCH better than the low point it was before
Drivers side has at least an inch in all directions
Spohn's
Mine
Car: 91 Trans Am
Pass side is about 1/4" from the frame, as close as I dare
I just like this pic
Nailed the shifter location
I still think the hardest part of this swap was the pedals. Column is still out waiting on a new IGN cyl. Bugs me to see an auto to manual swap without the key lock
Future projects waiting to go
To-do list is more of a punch list at this point
Finish up the fuel and AC system
Order a DS
Put the interior back together
Figure out e-brake cables/mounting
Build Y-pipe
etc
Missed my January completion date, but it wont be much longer. Hopefully work will let me be home long enough to have at least a little cruising this summer
Order a DS
Build Y-pipe
etc
Engine: 7.0L
looks good man, you're going to enjoy the six speed. your trans mount doesn't brake because of the solid motor mounts though
i have a stock mount on mine and have no issues since i have solid motor mounts.
