6.0 intake & accesories under this hood
Old Apr 16, 2010 | 02:21 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
i may be getting a complete 6.0 with every thing for 300! although it has slight high mile. do u think that the stock 6.0 intake and accesories will fit under this hood? i plan on changing them eventually.
Old Apr 16, 2010 | 02:43 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: 6.0 intake & accesories under this hood
The intake should definitely clear. You will probably have problems with the higher mount of the alternator.
This thread should answer all your questions on the subject.
Old Apr 16, 2010 | 02:54 PM
89lt1's Avatar
i figured the intake would but just wasnt sure how far forward the alt. actually is.
Old Apr 16, 2010 | 07:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I doubt either one will fit. The cowl doesn't start far enough forward.
Old Apr 16, 2010 | 07:17 PM
89lt1's Avatar
dang just my luck
one92rs's Avatar
Car: SOLD!!!!!
might want to look at zone89rs post in here. he has some resolutions on doing that.
Old Apr 17, 2010 | 12:49 PM
89lt1's Avatar
found it
Old Apr 18, 2010 | 12:42 AM
1bdbrd's Avatar
Car: 1991 Trans Am
You could still pick up the engine and just get yourself a stock LS1 intake for the time being. I have seen them as cheap as $25 on ls1tech. Then work out something with the accessories.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
