How to put an early style GM trans behind your LS motor
Old May 26, 2010 | 01:58 AM
IROCFAST's Avatar
I know this has been discussed here a few times. Putting an auto behind it is straightforward, flexplate/crank spacer and done, usually even the bolt holes on the converter and very close (old style is 11.75" new is 11.80"). Therefore, I was digging through some of my old mags, found an old CC article on how to do just this, and figured I would share. BTW, the GM crank/flexplate spacer is superior to the others.
Attached Thumbnails How to put an early style GM trans behind your LS motor-cc1.jpg   How to put an early style GM trans behind your LS motor-cc2.jpg   How to put an early style GM trans behind your LS motor-cc3.jpg
Old May 26, 2010 | 01:59 AM
IROCFAST's Avatar
Re: How to put an early style GM trans behind your LS motor
last 2 pages
Attached Thumbnails How to put an early style GM trans behind your LS motor-cc4.jpg   How to put an early style GM trans behind your LS motor-cc5.jpg
Old May 26, 2010 | 05:41 PM
IROCFAST's Avatar
online article
http://www.carcraft.com/techarticles...n_3/index.html
Old May 26, 2010 | 09:58 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
good info, thanks for posting it! check this guys 4speed swap out
http://yellowbullet.com/forum/showthread.php?t=231235
Old May 27, 2010 | 12:16 PM
chikn305's Avatar
I used the gm flywheel and spacer its definitely the way to go way cheaper than TCI stuff. The only thing I did was elongate the converter holes to line up with my PTC converter.
Old May 27, 2010 | 01:45 PM
IROCFAST's Avatar
I am entertaining the idea of my spare T-5 in one behind an LS in the 67 street car I am building. Everyone is down on the T-5, but if you talk to anyone who has owned a WC one, they are not nearly as easy to kill as people think. Mine lived behind my car that trapped @ 120mph for 2 years before I broke it. The tilted trans could be a pain because the bellhousing will not clear a 168t flywheel, still have to figure this solution out. I wish i could adapt a Tremec 3650 out of an 01 and newer mustang, those are pretty tough and can be had fairly cheap! But they are a 1pc bellhousing/trans deal.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
cRoe4
Aug 7, 2015 08:46 PM
Leggman1
Aug 6, 2015 04:15 AM
