Half an exhaust
Old May 26, 2010 | 11:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Half an exhaust
Finally got some pics taken this evening, thought I'd show you what I have so far. If you've followed the saga, the shop's bender went down for a week, so after getting it back up and running they took the pipes to the axle and I drove it home for the weekend - only to discover my rear end gears were toast.
Basic view showing the header collectors, pipes bent to get past the tranny to dual Magnaflow spun cats, H-pipe, then I-pipes to temporary turn-downs. All pipes are 2-1/2" mandrel bent, except the H-cross-pipe which is slightly smaller. The hangers were fastened to longer rear seat belt mount bolts.
Looking over the top of the left pipe at the modified driveshaft loop.
Clearance between the left pipe and the fuel/brake lines.
The right side is tucked a little tighter.
This really wasn't as loud as you might think - yes, it was loud, but when I got on it, sounded pretty much like the 5.0's that always seem to be running around. Cruising, the rear end was louder than the exhaust.
The rest will be finished after the 9" that is now being fabricated is installed. Pipes over the axle to an Aero Turbine muffler on each side.
Old May 27, 2010 | 12:51 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Half an exhaust
where's your torque arm?
Old May 27, 2010 | 07:08 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: Half an exhaust
Old May 27, 2010 | 07:57 AM
five7kid's Avatar
Ah, you haven't been following.
Torque arm? We don't need no stinkin' torque arm. . .
Old May 27, 2010 | 08:12 AM
RockJay81's Avatar
Re: Half an exhaust
wow that's cool. how does it feel better than stock or is it the same?
Old May 27, 2010 | 08:39 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: Half an exhaust
that my friend is AWESOME! Have you driven the car with that mod?
Old May 27, 2010 | 08:44 AM
five7kid's Avatar
Rides & handles fine. I haven't really pushed it in corners because I've only had skinny tires on.
I am going to add LCA relocation brackets with the 9". Should help it plant better.
Old May 27, 2010 | 09:19 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Half an exhaust
I've never heard of those mufflers you mentioned. What do they flow on a SuperFlow 1020? Hopefully over 590 cfm each, otherwise choose something else.
Old May 27, 2010 | 10:01 AM
ericjon262's Avatar
Re: Half an exhaust
how can I follow every thread about your car, as many as you have going!
Old May 27, 2010 | 12:07 PM
five7kid's Avatar
Haven't seen flow numbers. It's an unbaffled design, though.
http://www.youtube.com/watch?v=iDTTOa77efs
http://www.aeroexhaust.com/index.php...e-muffler.html (their site is slow)
Guilty as charged. . .
Old May 27, 2010 | 12:18 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Half an exhaust
Im really on the fence about those "ladder bars". I wanted to get a set of G-Force bars, but couldnt get enough feedback about them. Most threads about them turned into a back and forth between the "smart" guys that say they work great for the street and the other "smart" guys that say they are horrible.
Ide like to just build my own. Or modify my Spohn bars if nothing else.
J.
Old May 27, 2010 | 12:52 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Re: Half an exhaust
Nice setup, how do you keep the underside of your car so clean? My car had to have seen salted roads at some point lol
Old May 27, 2010 | 12:59 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Half an exhaust
looks good
rear setup looks sickk!!
Mikey
Old May 27, 2010 | 01:46 PM
five7kid's Avatar
Originally Posted by ghettocruiser
Im really on the fence about those "ladder bars". ... Most threads about them turned into a back and forth between the "smart" guys that say they work great for the street and the other "smart" guys that say they are horrible.
Ain't that the truth! I was seriously considering going back to the TA with the 9" after all the grief I've taken over it, finally decided I'm going to stick to my guns until forced otherwise.
This was a California car. To the best of my knowledge, it's never seen salt (certainly hasn't since I've had it). I'll probably keep it that way.
Berlinetta #1 is a completely different story. Although, it isn't too bad, either. Usually need to clean up and repaint a spot or two every year. Mostly, though, it gets its "undercoating" from the Gen I SBC. . .
Old May 27, 2010 | 01:58 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Half an exhaust
I love the dual exhaust. How does it clear on the driver's side? I couldnt tell from the photos.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Half an exhaust
Interesting, but I'd still get flow, or at least a dyno comparison to 2.5" unmuffled, before committing.
Old May 27, 2010 | 02:20 PM
five7kid's Avatar
I had a single 3" version on my '84 full size conversion van w/350. It made a big difference over the original 3" inlet/dual 2-1/4" outlet muffler that was on there.
Also not sure how a steady flow from a flow bench would compare to the pulsed flow of real-world exhaust.
(And, I already have the mufflers. . .)
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
customblackbird
Oct 1, 2015 04:30 PM
cstrobel65
Sep 16, 2015 11:54 AM
Lanz06
Sep 14, 2015 07:16 PM
Djmathis123
Sep 8, 2015 08:42 PM
