LT1 harness: Start to Finish
Old May 6, 2016 | 09:17 AM
  #51
CrazyE's Avatar
Re: LT1 harness: Start to Finish
Pocket, I'm new to the forum, is there anyway you can contact me. I'm interested in having an LT1 harness made up for a 94 Camaro to 88 Camaro swap! Thanks and I hope you see this lol!
Old May 10, 2016 | 10:17 AM
  #52
Pocket's Avatar
Car: 91 Trans Am
Sure, shoot me a PM or email me directly for a faster response
Old Jun 7, 2020 | 06:42 PM
  #53
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
you build me a wire harness 94 corvette lt1 with Vette AC the Ac connector was wrong finally found right Ac connector there is no alternator wire in the harness to alternator nut just the plug in help there five wires on right with nothing no connectors , working on 86 Camaro IROC-Z engine is 94 corvette LT! different AC compressor connector than the other LT1,s thank you
Old Feb 24, 2022 | 08:44 AM
  #54
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
Originally Posted by Pocket
I like to split the injector banks into two fuses for troubleshooting purposes. All EFI 3rd gens have 2 INJ fuses so this isnt a problem
For classic cars, one wire alt means just the rear lug. They know when to charge/not charge. Newer engines always have control wires for various purposes in addition to the mandatory cable on the rear lug. Counting them makes identification easier since several types were used for LT1s. For your fuse, it feeds the fan relay directly. The alt wire is teed on, with the resistor between the tee and alt so the alt never sees a full 12v. Running any of the newer alts at full 12v (actually 14v) will burn them up quickly
91 z28 97 lt1 t56 swap
need to put in a fuse for ign 10am and engine sensors 20amp what can i connect to?
So for the pink c100 ign wire connects to the ign fuse 10amp is there a fuse installed inbetween the pink c100 ign wire and the positive for my ign coil? Same goes for engine sensors or should i use the emissions common and is it gonna need a fuse asweel inbetween?
Old Jun 5, 2024 | 07:44 AM
  #55
burchtj's Avatar
Pocket I have a 1994 z28 and a 1996 LT1 out of a Caprice how much will Yu charge to build a wiring harness
Old Jun 5, 2024 | 07:50 AM
  #56
burchtj's Avatar
Old Jun 9, 2024 | 08:24 AM
  #57
Pocket's Avatar
Car: 91 Trans Am
I'm no longer building mail order harnesses
Old Jun 10, 2024 | 03:07 PM
  #58
burchtj's Avatar
Do you know of anyone that makes them and mail them I'm not car savvy at all
midge54
Dec 27, 2019 04:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
midge54
Jan 29, 2017 07:00 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
