Lt options
Old Jul 15, 2010 | 09:16 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Lt options
Hey guys, I'm in the middle of a lt1/t56 swap in my 84 trans am. I'm got a cc503 cam and le2 heads and intake. The motor has around 20,000 miles on it out of a 93 camaro. Some of the guys I work with have novas and lightnings that run bottom 11s and 10s. My question is, what should my car run with this setup? Should I just build it to a 396 with a bigger cam? And those heads or should I look into procharging the stock bottom end? I want a constant power gain, so no nitrous for me. Just throw out some ideas for me guys.
Dustin
Old Jul 15, 2010 | 10:55 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Lt options
i think that cam may be a bit small for the LE2 package. I have the same thing in my camaro and I can't remember if it was that small. If you stroke your engine to a 396, you are going to have to upgrade everything else. In my opinion, A stout 383 with the right heads/cam will be perfect. And, if you build it right, you can add the supercharger as well. This combo will still find your weak link and I think you will be replacing driveline parts until they are upgraded as well.
Old Jul 15, 2010 | 04:02 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: Lt options
I agree with 1981LT1 the cam is small with those heads call Lloyd and have him spec a cam for you.
Old Jul 16, 2010 | 09:03 AM
1badeagle's Avatar
Engine: 370 LSX
Re: Lt options
Ok, thanks guys. Any idea what I will run with this setup
Old Jul 16, 2010 | 05:11 PM
Car: 1992 camaro
Axle/Gears: 3:73
Re: Lt options
It depends on how old the heads are,years ago he had no "stages"on heads.
I asked Lloyd the question about hp with this set up and he told me around 375,but that was with long tubes.
As for what it will run that depends on alot of things. Call him and talk to him he will spec you a cam and you can run 11's all day, may not be much of a dd though.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
