Could 5.3L truck acces. fit w/ different alt?
Car: '92 Z03
Engine: LSX
Transmission: M12
I'm wondering if anyone has tried running the F-Body alternator or even an earlier model CS130 alternator in the 4.8L / 5.3L Truck accesories and got that to clear their factory hood.
Could it work?
Could it work?
Re: Could 5.3L truck acces. fit w/ different alt?
It's not the size thats the problem, it's the location. After that's taken care of, the intake hits. Once swapped for a car style intake the WP neck hits the TB cam. Once the WP is swapped for a front neck (car style) the accessory depth changes. This requires either a custom WP or swapping to the car accessories
Several threads exist though showing clearance of the truck stuff under a RA2 or cowl hood, just nothing factory will work easily
Car: 1987 Trans Am
Engine: LQ9/L92
the accessory cost definitely does stink to have to add to the truck swap list, but its a necessary evil as pocket said. you can't mix and match different setups and there's just no way to make the truck stuff work in the car if you've got a stock hood.
i kept following the classifieds section on ls1tech and snagged a new bracket setup for $200, just gotta be patient
327_TPI_77_Maro
Oct 28, 2004 01:13 AM
fb305svs
Sep 26, 2000 10:52 PM
