SBC casting numbers- need info about the block etc...
Old Sep 25, 2000 | 07:52 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
hey guys, as some of you know, i have a chance to buy an already built and brokin motor for my car. here are all the casting numbers for it:
front of block- V0710TPD
Back of Block-
14093638
GM5.7LG
SGI
F299
Head number- 333882
Also, about the accesories. the heads only have acces. bolt holes on the drivers side of the motor. not the pass. is there brackets that i can get to mount all the accesories? like power steering, alt and ac?
and where can i get them? i was hoping to transfer my current acces. but that is not gonna happen it looks like. also, if you could let me know if it is a one piece seal and a 4 bolt main, that would be good too! thanx guys- i was kinda disappointed... wasnt what i thought it was.
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: GOT A 350 IN THE WORKS BABY! gonna throw my TES edlebrock headers on it, and hopefully get some more gear and the cowl hood on
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Sep 25, 2000 | 08:25 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
From www.mortec.com .......
14093638...350...87-95...2 or 4 bolt main...Roller or flat tappet cam, one-piece rear seal.
333882...74-80 350/400, 76cc
These heads are off an earlier motor so they should have 3 acc. bolt holes on one side and 1 on the other.
This would mean that you will have 3 bolt holes on the drivers side and 1 on the pass. side head.
This could be a good block, if its a roller.
The heads are nothing special.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 25, 2000).]
Old Sep 25, 2000 | 08:46 PM
fb305svs's Avatar
ok cool- yeah i thought the kid said it was a roller block. the heads as far as valve size- 196 174?
they arent 2.02's right?
anyhow, we'll see, the accesory bolt hole is on the back of the head on the pass side.. there are three on the drivers side....
Steve
Old Sep 25, 2000 | 09:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
There should be one bolt hole (for the alt pivot bolt) on the pass. side.
As far as valve size I belive they are 1.94/1.50
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Sep 25, 2000 | 09:27 PM
fb305svs's Avatar
its there... but on the back of the head, not the front... i looked closely for this... unless the altenator goes on the drivers side...
Steve
Old Sep 25, 2000 | 09:52 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Thats wierd.....I have 2 sets of "882" casting heads in my garage and they both have all the acc. bolt holes. Hmmmm.
This may be a stupid question but are both heads the same casting numbers??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Sep 25, 2000 | 10:01 PM
fb305svs's Avatar
well, the one that has the backwords bolt hole is the one i took the number off of... it doesnt have three so it cant be on the wrong side!
Steve
Old Sep 25, 2000 | 10:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
OK, OK, .....
Maybe it didn't get drilled.....Hmmm.
I've never seen that.
Anybody else??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Sep 25, 2000 | 10:21 PM
fb305svs's Avatar
yeah kinda wierd... the bolt hole is on the back though...
Steve
Old Sep 25, 2000 | 10:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All the heads up through the late 80s, if they had any bolt holes at all, had one hole in one end and 3 in the other. When installed there will be one at the right front and left rear, and 3 at the left front and right rear.
Those heads are not very good regardless of what size valves they have in them. They came with 1.94 intakes. All through the 70s and early 80s, people who had them got beat by people who had less money in theirs and smaller cams and such, but better heads. One of the worst combos was those heads and dome pistons; looks good on paper, but just doesn't run. They were the ones that came on such enviable powerhouses as the 165 HP 350s from about 74 to 79.
Old Sep 25, 2000 | 10:57 PM
fb305svs's Avatar
well, i am not expecting these heads to be big power houses... however, i am concerned about bolting on my acces...
Steve
Old Sep 26, 2000 | 10:52 PM
fb305svs's Avatar
does anyone know where i can get the accesory brackets for the motor to hook everything up?
steve
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
roysatikas
Sep 7, 2015 08:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
