LS1 motor mounts. Poly vs regular
Old Aug 10, 2010 | 07:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a stock set of motor mounts but I'm thinking of swapping in poly mounts instead. Is it worth it? Does it raise the engine any like the old SBC mounts did? Basically a stock LS6 headed and intaked 6.0L with a 228/230 112 cam.
Old Aug 10, 2010 | 07:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LS1 motor mounts. Poly vs regular
The engine doesnt lift like the old SBCs did, same spot. Down side is teh through bolts are a bit tricky to shoot through because poly doesnt move as much
I would HIGHLY recommend the poly kit with the LSx engine. Take a ride in a 4th gen LS1 with rubbers then another with polys. Totally different car in a good way
Old Aug 10, 2010 | 11:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The stock rubber inserts are tiny compared to the poly inserts.
Old Aug 11, 2010 | 12:41 AM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I vote poly if you have the engine out already, BlueZee28 did his in the car and I believe he had a hard time. I did mine while the motor was out and it was a piece of cake (somewhat lol)
Old Aug 11, 2010 | 08:17 AM
Pocket's Avatar
Car: 91 Trans Am
Did mine with the motor in, but swapping K-members. Wasnt too bad
Old Aug 11, 2010 | 10:45 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Ya, I wouldnt try it with the motor and k member in the car. If you're gonna do it, take it back out first.
LittleFranks
Sep 17, 2015 12:22 PM
zayne0
Aug 24, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
NBrehm
Aug 5, 2015 07:57 PM
