help swap problem
Old Aug 7, 2010 | 09:21 PM
dark light's Avatar
help swap problem
heloo every body
this is my first topic in this board .
I want to ask you guys about :what is the most popular engine you have swap in the third gen
I have many choices : LS1 , 6.0 iron block ,Lt1 , 454 BB ,350
my project is : I want the most power with stock bottom engine and N2O in weekend drive
I have 1987 red iroc no motor no trans ,
so guys i want to help me in my Project
Old Aug 7, 2010 | 09:44 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Re: help swap problem
There are a lot of factors in Engine swaps. It depends on your mechanical aptitude, and moreso your electronics aptitude in terms of the LSX Swaps.
What are you looking to spend? I saw you mentioned doing NOS on a stock bottom end. If it were me, I'd be looking for a 5.3 Truck engine with an LSX intake, maybe cam, and headers. That would give you a pretty stout engine doing maybe 350 to the pavement then whatever NOS you plan on spraying.
6.0 is a great option here too, but they're harder to find and are usually almost double the price of the 5.3 from what I've found.
Old Aug 7, 2010 | 09:54 PM
dark light's Avatar
about the 6.0 i can deal with it but my major problem with this engine is the weight of it . about the electronics aptitude am planning on carb and Distributor
Old Aug 7, 2010 | 10:00 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
The 6.0 is not any more weight than the 350 you have listed. It may even be lighter, and its significantly lighter than the 454 you have listed. I recommend you do some reading on this forum. You could probably acquire all the info you need to make your decision.
Old Aug 7, 2010 | 10:07 PM
dark light's Avatar
woulde you pls help me and but for me some links?
my target to get most power for street and strep race.
as i sayes carb and N2O in auto trans
Old Aug 8, 2010 | 11:47 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Read this
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Aug 8, 2010 | 12:32 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
It sounds like you really want to get this thing going, well I'm a bit further ahead in the process, so whats required is quite fresh in my mind. I'll give you what I consider to be the best advise here.
Read, read, read, then do, do, do.
I recommend starting with all the sticky threads in the forum. Read everything. Then start with each one of the build threads, and read all of them.
Why?
Its simple. Everyone that has performed a swap on this forum has run into snags of some sort in their project. Some are the same snags that most everyone encounters, but each project has its own unique ones. By learning, and reading what others have run into, it will help you to better prepare yourself for what you will run into.
Here is an example of a Carbed LSX Engine build thread:
https://www.thirdgen.org/forums/ltx-...ost-there.html
You may notice that they are using the LSX Coil Per Cylinder Setup, and there is no distributer, which lends back to my previous recommendation, which is to prepare to set up a harness for you car. I may be wrong on this, but I don't think there is a provision for a distributer in an LSX block.
Old Aug 8, 2010 | 01:29 PM
Pocket's Avatar
Car: 91 Trans Am
Good advice
GMPP sells a front cover kit that allows the use of a Ford SB distributor up front driven directly off the cam. Theres a good pic thread on 'tech with one in a minimalist G-body
IMHO carbing a LSx throws away half of the R&D GM put into the new engine platform
Old Aug 8, 2010 | 01:53 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Use the MSD 6010 controller and a carb and beat the hell out of it with whatever cam you like. The distributor is a waste of time unless you are spinning over 7700 RPM.
Here is my build:
https://www.thirdgen.org/forums/ltx-...-6-0-swap.html
So far, everyone looks at my tail lights that is running on motor but2 i have run, 1 i helped build and the other was stroked with heads that cost more than what i paid for my drive train.
Old Aug 8, 2010 | 02:49 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Thanks for the correction Pocket, I knew I'd seen that somewhere but since I'm not interested in taking a step back in tech I forgot about it. Despite the fact that it is ultimately your choice what you run, I have to agree whole heartedly with Pockets remarks on going Carb on an lsx. I'm not saying they went fast or good, but that GM pit a lot of work and R&D into making. The injected LSX the best, streetable small blocks in the world. The other manufacturers are doing what they can to emulate it. Again, running whatever you want and enjoy it, but IMHO the tech is there for a good reason, and for good benefit.
Old Aug 9, 2010 | 03:11 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, it is different stroked for different wallets/folks. The cheap way to make a bunch of power was a carb for me, , i just have an alternator and water pump, no PS, AC or any of that, i would go EFI if i had the cash maybe, but i would still run a Victor intake with a TB on top. Just cost too much for myself, if my car was a 98 up OE EFI car, of course i would not "step back", but as my car had a TBI engine, a carbed LS is no step back by any means, LOL.
Old Aug 9, 2010 | 08:40 PM
dark light's Avatar
Thank you all guys for your post
Ido alot of researching and am still lost
i have a good budget for ls1 engine
but the qustion is :
does the 3 red gen camaro worth the effort for this project
I mean for ls1 and carb
I choose the carb than the EFI because we do not have
perfect tuner
and the carb is cheaper
I do not care about the A/C and the steering wheel
Old Aug 9, 2010 | 08:49 PM
dark light's Avatar
Here is my build:
dud how many horsepower did you get from your project ?
my opinion in the distribution is that i can instal msd 6AL and i can control
by my own for adjustment and i do not have to need the coil and computer
Old Aug 9, 2010 | 09:36 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
write in the normal font color and size lol
Old Aug 9, 2010 | 10:28 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
ooh, can't do that... if you type in normal font, color and size, then people don't have to think hard as they read your comments. er... do they?
instead I'll just add in a bunch of emote icons:
Old Aug 10, 2010 | 11:23 AM
dark light's Avatar
sorry guys for this error but in my computer it shows Pretty format LOL
Idid adject what i write so guys plz comment on my commentLoL
Old Aug 10, 2010 | 12:05 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Hehe, just giving you a hard time! Best of luck with your swap!
Old Aug 10, 2010 | 11:42 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Dont know how much power it makes since i have not dynoed it, but i destroy heads and cam LS1 camaros and firebirds with ease. By the time you aford the conversion you can get a lap top new for 200$ from wal mart or a used one for less and the 8 coils work better for dwell time.
Old Aug 10, 2010 | 11:50 PM
dark light's Avatar
what kind of model you have been distroyed dud
Old Aug 11, 2010 | 12:58 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
98-02 TA, Z28,SS, 97-04 HCI ZO6 vettes, turbo handas(with VTAAK), mustangs with cams and nitrous, ect.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
