Motor upgrade question
Old Aug 22, 2010 | 04:53 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
Ok, if any of u have been following i am going from a stock lt1 to a 383 lt1 with a cam and fuel injector upgrade. Now should i install the motor fire it up using the prom that I have then tweak the it? or should I have the computer programmed pryor then tweak it again? What would you or have some of you done?
I have asked a lot of questions and have gotten some great advice. Here are some Advance Auto coupon codes for you DIYers. I been picking up parts for cheap all summer!!!! Passing them along as a thank you. If u dont like Advance u can at least stock up on oil and filters. (and brakekleen)
Apply 20% off entire order coupon code "P20" on it (Expires 08/31/2010)
$10 off $30, $20 off $50, $30 off $100 w/coupon code "ES123"
Apply $25 off $60 w/coupon code "BIG25",
$30 off $75 via coupon code "BIG30",
$40 off $100 w/coupon code "BIG40"
& get $50 off $200 via coupon code "BIG50"
Old Aug 22, 2010 | 08:57 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Motor upgrade question
saw these a couple days ago too, i ended up using 2 of these this weekend myself
new gaskets, some oil change goodies (oil's not allowed on the coupons though), and some new tools.
as for the startup, go for it if you have some tuning software to watch what's going on inside the motor. just keep an eye out for pings and running too lean
Old Aug 23, 2010 | 01:26 AM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
that may be temporary because i have bought mobil1 b4 using a coupon. I remember because walmart usually is .50 to a dollar cheaper. thats the only reason i bought it from AA. or maybe they have done away with that option.
Old Aug 23, 2010 | 07:24 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I would have the PCM tunned befor you fire it up unless you are just going to see if it will start and shut it back off.
Old Aug 23, 2010 | 08:42 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
I didn't even think it would run, but I was told that it will. I am trying to debate wether to just send the pcm off to someone who has done a lot of them and leave it at what they program or get it running then tweak it at the track. Leaning towards just sending it off.
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
Fronzizzle
Aug 19, 2015 01:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
