Hawks Tranny X member issues with SFC?
Old Aug 22, 2010 | 05:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the hawks tranny x member for the 4l60E but there is no way in heck its fitting with the Alson SFC's anybody else run into this issue with a solution?
Old Aug 22, 2010 | 05:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Hawks Tranny X member issues with SFC?
what crossmember? a stock one? or aftermarket like Spohn or something? Does hawks make their own, idk? can you trim the mounting flange to clear where it hits the Alston SFC mounting flange?
Old Aug 22, 2010 | 06:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I thought about trimming but it would be trimming alot!!! Even then it may not fit on the passenger side. Its hawks brand cross member for the LSX swap.
Old Aug 22, 2010 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i think i found the link on their site, and it looks like there is a lot of material hanging off the tail end og the subframe, if thats what in the way, chop it off, it doesnt do anything.
maybe a pic of the issue on your car?
Old Aug 22, 2010 | 07:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Your correct. i could get away with it on the driver side But i dont know about the passenger side. I'll try to get a pic tomorrow
Old Aug 22, 2010 | 08:52 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
definitely interested in seeing pics. I was thinking of getting alstons and this member for a better exhaust fit.
Old Aug 22, 2010 | 09:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
ehh I'm go crawl under the car now. Give me 10 minutes lol.
Old Aug 22, 2010 | 09:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ok, it wont fit even with chopping. First pic is with the held up on the driver side. The outline in red is the alston mount. I can chop 4 inches off the hawks member and be ok. Second pic is passenger side. The lin represents what I would have to chop off. Needless to say the cross weld point is on that other side. no dice...
Attached Thumbnails Hawks Tranny X member issues with SFC?-017.jpg   Hawks Tranny X member issues with SFC?-018.jpg
Old Aug 23, 2010 | 01:31 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
its a spohn piece i would think. Im pretty sure thats who Hawks sells. Bluezee28 and myself have both come across this problem. You have to cut a bunch of it off for it to clear the alston subframe connectors.
https://www.thirdgen.org/forums/ltx-...ad-6-0l-5.html start with post #249
Old Aug 23, 2010 | 10:59 AM
Pocket's Avatar
Car: 91 Trans Am
Spohn piece is very bulky and makes exhaust routing difficult
Id notch out the material to clear the SFC then weld a plate over top to get the structural rigidity back and clear the SFC point. Grinding some of the excess metal off the SFC wouldnt be a bad idea either
Old Aug 23, 2010 | 04:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Its not the spohn one. Its their own brand. They sell their brand and the spohns.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
crazynights
Aug 21, 2015 06:53 AM
drathaar907
Aug 6, 2015 04:20 PM
