SPEEDOMETER SIGNAL HELP LS6 SWAP
Subscribe
Sep 15, 2010 | 02:02 PM
I HAVE A 91 CAMARO WITH AN LS6 T56 CONVERSION WITH A PSI STAND ALONE WIRING HARNESS. IT HAS A SIGNAL OUT PUT WIRE COMING FROM THE ECM. CAN I HOOK IT DIRECTLY TO THE SIGNAL INPUT ON MY ELECTRIC SPEEDOMETER OR AM I GOING TO NEED A SIGNAL CONVERION BOX LIKE THE FACTORY BOX THAT COMES IN THE CAR, IF THATS THE CASE HOW WOULD I GO ABOUT HOOKING IT UP?I CALLED THE PSI COMPANY REP, AND HE TOLD ME HE WASENT SURE IF I COULD HOOK IT DIRECTLY TO THE SEEDOMETER OR IF I WAS GOING TO HAVE TO GOT A DIFFERENT ROUTE.
Reply 0
Sep 15, 2010 | 09:30 PM
Re: SPEEDOMETER SIGNAL HELP LS6 SWAP
Hey D2, I dont know alot about this, but what I have learned by trying to find out info about my LS T-56/speedo sending unit working with my 92 speedo is that the Digital interface SGI-5 from Dakota Digital will do the job, apparently. But I'm still not fully convenced that it is necessary ever since I saw a aftermarket replacement LS T-56 speedo sending unit that was advertised as "dual phase", but it failed to say which phase's. But at $79 bucks, its not that bad, for the SGI-5. They also make one for the tach, SGI-8.
Reply 0
Sep 15, 2010 | 09:38 PM
Ok i will check that out thank you. Since the cammaro came with the signal converter box i am wondering if there is a way i can use that one, save some money you know.
Reply 0
Sep 15, 2010 | 09:52 PM
Its Pulse not phase. My bad, its ppm, and they're different from 3rd gen to 4th gen, even though both speedometer's are electric. Let me know wha cha find out. Thanks.
Reply 0
Sep 16, 2010 | 07:20 AM
Read the stickys
Just hook the output wire directly to your tach input. If the value is wrong, change the engine mode (LSx output 4cyl signal). If the tach doesnt move at all, use the booster wire
No converter box is required for electric speedos. LT1 T56 onto an older engine require the box because the newer electric VSS output 11 or 17ppr (pulse per revolution of the shaft) for T56 and 40ppr 4L60E. 3rd and 4th gen speedos are driven by 4000ppm (pulse per driven mile). Your LTx/LSx PCM will convert this for you. When the vanilla trans is bolted on, there is no PCM to do this conversion so it must be addressed with a box
Reply 0
Sep 16, 2010 | 08:01 AM
So if I dont have any pcm, I need a box. Oh, sorry for my ignorance but I dont know what the "sticky's" are.
Reply 0
Sep 16, 2010 | 08:48 AM
i will let you know its going to be a couple weeks i ave to go to ntc in cali for a lil bit but when i get back i should know some thing
Reply 0
Subscribe
