She is alive !!! LS1 Startup inside !!
Old Oct 4, 2010 | 08:41 PM
Iroc-N-Rollz!'s Avatar
Car: 1988 Iroc-Z
I've had the car running for a bit now, but it actually started to idle worth a damn so i record this video for yall (Special thanks to Pocket for the Harness and troubleshooting info).
http://www.facebook.com/video/video....ideo_processed
Old Oct 4, 2010 | 09:02 PM
Pocket's Avatar
Car: 91 Trans Am
Re: She is alive !!! LS1 Startup inside !!
That thing sounds NASTY
Old Oct 4, 2010 | 09:18 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
sounds pretty sick nice job.
seems like our interior taste of driver side doors match
Old Oct 4, 2010 | 09:21 PM
Car: 1988 Iroc-Z
Yea the interior still needs to be put back together, Its been along road and im glad to be approaching the end lol.
Old Oct 4, 2010 | 09:31 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
sounds good
Old Oct 4, 2010 | 09:50 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I bet it sounds awesome in person. Unfortunately, my speakers on my laptop suck, so I can't hear much of anything. Good job on the first startup!
Old Oct 4, 2010 | 10:29 PM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
SOUNDS AWESOME!!! What Cam do you have?
Old Oct 4, 2010 | 10:36 PM
Car: 1988 Iroc-Z
Its still untuned, but it has a 228R Texas speed cam. I think im going to regret going so small, but i really was wanting more of a DD friendly cam. Thanks guys for the kind words, about 3 year project in the making.
Old Oct 4, 2010 | 10:39 PM
BlueZee28's Avatar
Daily drivability is a relative term. One mans race car is another mans grocery getter. What's the specs on the block? 5.3 5.7 6.0, other?
Old Oct 4, 2010 | 11:08 PM
Car: 1988 Iroc-Z
Indeed, but i've heard cams in the 230+ duration and they don't sound desirable especially with AC. The motor is a LS1 from a 99 WS6, I swapped in some Stage 2.5 5.3 TSP heads and im running a .40 MLS head gasket. So my compression should be around 11:1.
Old Oct 4, 2010 | 11:11 PM
BlueZee28's Avatar
Mines a 239/242 and I love it, although I don't have a/c.
Old Oct 5, 2010 | 12:46 PM
Car: 1988 Iroc-Z
Whats the lift and LSA on it ? I'll probably get a Custom grind from Pat G over on LS1tech, but im sure i'll be able to lay down enough power to do some mid 11's.
Old Oct 5, 2010 | 02:47 PM
BlueZee28's Avatar
I forget the exact lift but it's like 64x/64x and on a 111lsa. It's Texas speed's MS4. And I should definitely be in the 11's after I get my 8.8" from Cam.
Old Oct 6, 2010 | 09:07 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Sounds great! What a beast!
Old Oct 6, 2010 | 09:34 AM
Car: 1988 Iroc-Z
My buddy had a 6.0 with the MS4 Cam, that thing sounded vicious !!! Im sure that cam plays hell on Vavle springs as well.
Old Oct 6, 2010 | 09:35 AM
Car: 1988 Iroc-Z
Thanks bud !!
Old Oct 6, 2010 | 10:14 AM
BlueZee28's Avatar
Ya it's got a nice chitty-bump. I went with the PAC dual springs, and it has a slight sewing machine sound to it, not bad though. I cant complain, it's a cam only setup with stock heads and an LS6 intake and at the wheels it's 420/407.
Old Oct 6, 2010 | 11:15 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
That sounds absolutely terrifying- I WANT ONE! Have to go now- I have to run over to the grocery store in my 3.1 v6
Old Oct 6, 2010 | 12:13 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
very nice!!! sounds great, you need an a/c delete box though, changing spark plugs are alot easier with one...and it saves some weight.
Old Oct 6, 2010 | 03:05 PM
Car: 1988 Iroc-Z
That would defeat the purpose of knotching the K-member for the 4th gen ac compressor =P. I totally agree with you on the Spark plug changing, but im blessed with small hands
Old Nov 15, 2010 | 12:29 PM
Car: 1988 Iroc-Z
I finally got around to putting Exhaust underneath it. Hawks 1 3/4 LT's 3in collector, 2 1/2 piping, Magnaflow X-pipe, 1 Chamber flowmasters routed out the back with flanges incase i need to drop the rear end. Enjoy !!!
Iroc-Z True Dual 1 Chamber Flowmasters
Linson
Oct 24, 2025 02:00 PM
dusterbd
Sep 29, 2015 08:40 AM
