Lsx swap mpg
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Lsx swap mpg
Hi i am wondering what all of u guys get as mpg on your lsx swapped cars i don't know if this is appropiate to ask in this part of the forum but i would really like to know the mpg you guys get since im saving up for lsx swap and since my car is dd i would like to get the best mpg.
Thanks for you for taking your time and reading this.
Re: Lsx swap mpg
5.3/4L60E/2.73's
N/A, 27ish highway driving like I stole it
With the blower, 20ish highway, 15ish city
LS1/T56 cars commonly hit 30-35mpg pretty easily, just dont go huge on the cam
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Lsx swap mpg
Wow so u practically get the economy of a v6 with a v8 thanks alot for your answer, what kind of blower do you have on your car.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Lsx swap mpg
Just remember in the great Republic of California you are limited to what type of LSx motor you can put in your car due to emissions, and have to retain all emissions equipement for it to pass.
My '98 with 188k miles on it gets around 27 on the highway with a T56 and 3.42 gears on a very long trip, but my daily driving nets me around 25.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Lsx swap mpg
Well yea im aware of that but i also know lots of smog shops that would do me a favor since my dad known them for a while.
Car: Camaro
Engine: 6.2L
Re: Lsx swap mpg
I actually thought my Fuel sender mod didnt work when i first started driving mine the mileage was so damn good the gauge seemingly took forever to move off full. I hammer the snot out of it and it truly gets phenomenal mileage
Re: Lsx swap mpg
I average about 18-20 as a daily driver with a combination of spirited driving, stop-and-go traffic(Cali)., along with some freeway miles. Not bad for a head and cam set up making about 400rwhp.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Lsx swap mpg
I get 20 MPG with driving on the freeway and a bit of stop and go with a carb. Now, when i beat it like a step child, not so good.
Transmission: 4L80E/4L80E
2000 LS1/4L60E, stock cam, shaved 317 heads, LS6 intake & injectors, Hawks long tube headers into 3" cat-back with single in/out Magnaflow, 3000 stall lock-up converter, 3.73 gears, short 24" tires, stock tune. 24.8 mpg on a 793 mile round-trip weekend before last. Return trip was from low elevation to high, was bucking a good 30 mph headwind for the last couple hundred miles.
I don't have a good reading on commuting mileage yet. I don't have the speedometer working yet, was using the Garmin for the above data.
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Lsx swap mpg
Motor mods in my sig. Built T-56. Strange 12-bolt w/3.73s.
I avg about 30-32 Hwy, and overall avg about 25. Only a little less than my 2.0 auto Jetta. And Im NOT easy on it.
J.
J.
Engine: Cammed 6.0L LSX
Re: Lsx swap mpg
6.0/t56/3.42's. I will admit the only time I have calculated my mpg was on my trip to power tour which was a mix of highway driving, city street driving, and two burnouts. I got 19mpg on that tank. I'd imagine if I was a little easier on it I could get high to mid 20's. It's got a pretty nasty cam so I don't expect to see the optimal mpg for an ls motor.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Lsx swap mpg
Wow everybody gets good mielage now im wanting to do the swap even more then before.
Car: 91 Firebird
Engine: 6.0
Re: Lsx swap mpg
I have a cammed ls1/T56 with 3.73 gears and I avg 16-18 city, 23-25 hwy
my tpi car did better lol
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: 91 Firebird
Engine: 6.0
Re: Lsx swap mpg
my tpi setup managed around 22 city, 30 hwy with a cam, heads, 3.42's and a T56
plus it ran mid 13's
My lt1 swapped 3rd gen avgs 21-23 city, 39-31 hwy with 3.42's and a T56
so I at least expected that kind of mileage when I spent the money for the lsx swap.
Car: 86 Trans AM
Re: Lsx swap mpg
Thats weird... You should be getting better than that just on gearing alone with the T56.
My 305 TPI NEVER got close to what my set up does now. It was like 20 on the highway, 16 in the city...MAYBE.
Are you running a huge cam? Is your tune spot on? Something seems weird there since Im modded a good bit more than you and pull much better mpg. Unless you have one nasty cam haha.
J.
J.
Car: 91 Firebird
Engine: 6.0
Re: Lsx swap mpg
Nope, nothing too radical with the cam.....
my TPI setup had a T56 behind it too, so thats something to consider.
Re: Lsx swap mpg
The T56 really helped you out. My old LO3/Auto peaked at 32. It was worn out barely hitting 25mpg when I pulled it. 91 GTA made 25mpg through a bone stock L98/Auto
Id still take my measly 5.3 over both of them
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Lsx swap mpg
my 99 z28 with bolt-ons and a T56 with 3.42s got 27+ driving 90 miles round trip to work with HEAVY 17x11 Zr1s and 315 nittos. wasn't really driving for gas mileage either.
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Re: Lsx swap mpg
My 6.0L/700R-4 nonlock-up/3.50 gear carb setup gets about 15mpg
Thats why im converting to efi.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Lsx swap mpg
thing is nuts..
