Ozz1967
close
Hey guys,
I was just curious about this. I know swapping in an LS1 into our cars is very popular and with some of the new ignition items out there that allow you to swap carbs onto them, I was curious if anyone has done it and has kept their original CCQjet? I'm also curious because I think I would like to do this swap eventually, most likely 2+ years down the road if I can find an LS1 (or LS2, LS7 etc) on the cheap.
Why spend all that money on an LSx swap then keep the stock Qjet?
i dont believe anyone has a spreadbore manifold for these cars and the computer setup for the qjets would be a gigantic step back. any particular reason why you're contemplating this? it won't be cheaper than current options out there and you've still gotta figure out how to set up a distributor to be controlled by the ancient engine computer.
really best to stick with the tried and true on these engines - stock fuel setup or edelbrock/msd + aftermarket carb
Ozz1967
close
Quote:
Couple of reasons, one of which is I firmyly believe the Qjet is superior to any Holley or Edelbrock. Second, my Qjet has already been rebuilt to support a 400hp 355 thats in my T/A now. The other primary reason is to pass inspection (back home is visual so I need smog pump and AIR tubes etc.) I know that people have installed carbs on LSX motors and have them run fine, so I was thinking it may be easier to keep my stock computer, fuel pump, fuel lines etc. And mae that work than buying all new stuff and ripping out the old.Originally Posted by Shift06
Why spend all that money on an LSx swap then keep the stock Qjet? Junior Member
Quote:
You have a CCqjet that puts out 400hp?Originally Posted by Ozz1967
Couple of reasons, one of which is I firmyly believe the Qjet is superior to any Holley or Edelbrock. Second, my Qjet has already been rebuilt to support a 400hp 355 thats in my T/A now. The other primary reason is to pass inspection (back home is visual so I need smog pump and AIR tubes etc.) I know that people have installed carbs on LSX motors and have them run fine, so I was thinking it may be easier to keep my stock computer, fuel pump, fuel lines etc. And mae that work than buying all new stuff and ripping out the old. Supreme Member
it can be done. with an adapter. yes qjets can handle 400hp easily. make sure you get a big cowl hood.
i suppose it is not an electric qjet either.
http://www.edelbrock.com/automotive_..._spacers.shtml
Sounds like a cali swap and you wouldnt be able to use a carb on a LSx anyways. When doing and emissions friendly swap the swap must meet the emissions standards of the new engine and since none of the LSx engines came with them youd automatically fail visualCouple of reasons, one of which is I firmyly believe the Qjet is superior to any Holley or Edelbrock. Second, my Qjet has already been rebuilt to support a 400hp 355 thats in my T/A now. The other primary reason is to pass inspection (back home is visual so I need smog pump and AIR tubes etc.) I know that people have installed carbs on LSX motors and have them run fine, so I was thinking it may be easier to keep my stock computer, fuel pump, fuel lines etc. And mae that work than buying all new stuff and ripping out the old.
five7kid
close
I maintain that the cheapest LSx is a complete dropout, which will include all the induction, harnesses, PCM, transmission, etc. You would have to spend more to get a CC q-jet adapted to the engine, and you would not have as good of a system.
I personally haven't heard of anyone trying it. The carb LSx swaps that are done are using an aftermarket box that uses the LSx coils, cam & crank sensors, etc. And, they are all squarebore carbs. I suppose you could figure out a way to tell the PCM to pulse the MCS and use the TPS signal from the carb, but, wow, what a science project!
Plus, the carb'd LSx systems require a cowl hood. EFI doesn't.
Quite frankly, by the time you've invested the money that you will no doubt have to invest to get that CCQuadratoilet carb to work well with an LSx motor you would've easily been able to keep the injection system that came on the motor, which is far superior to the carb anyway.
I'm not so great at sugar coating stuff as you can see. My advise: Dump the carb, use a full drop-out and never look back!
five7kid
close
Quote:
Doc says I need to reduce carbs. So, I'm 100% EFI now... Originally Posted by Falconiroc
(Except I'm still moderating the Carburetor forum...)
Ozz1967
close
So the question then is, will my factory fuel lines that were originally made for a carb handle the pressure that an EFI system runs at or would I have to run new fuel lines from a later model fuel injected car?Originally Posted by five7kid
I maintain that the cheapest LSx is a complete dropout, which will include all the induction, harnesses, PCM, transmission, etc. You would have to spend more to get a CC q-jet adapted to the engine, and you would not have as good of a system.I personally haven't heard of anyone trying it. The carb LSx swaps that are done are using an aftermarket box that uses the LSx coils, cam & crank sensors, etc. And, they are all squarebore carbs. I suppose you could figure out a way to tell the PCM to pulse the MCS and use the TPS signal from the carb, but, wow, what a science project!
the issue you have with the lines is that they're all clamped; you could have the ends flared to accept fittings and go that route, but the rubber that's in place now is not sufficient for the pressure of the FI setup. However, still a small drop money-wise compared to the rest of the swap (running into this issue myself right now on my 87)
Quote:
OMG, that comment made my day. That just became my facebook status.Originally Posted by five7kid
Not everyones perfect (Except I'm still moderating the Carburetor forum...)
People do it all the time but it is dangerous. Easiest upgrade for a solid fuel system is using a 3rd gen EFI sender in the tank (threaded fittings) and AN6 lines up to the rails. PNs are posted for the C5 regulator in the stock locationSo the question then is, will my factory fuel lines that were originally made for a carb handle the pressure that an EFI system runs at or would I have to run new fuel lines from a later model fuel injected car?
Ozz1967
close
Braided lines from the fuel tank all the way up would be...expensive.Originally Posted by Pocket
five7kid
close
Ozz, I know you've been trying to work through CC carb issues. Why do you want to perpetuate the pain? (Said never having had CC carb problems myself.)
As for the carb fuel lines and EFI, not saying my way is the only way, but here's what I did for the LS1/4L60E: EFI pick-up (from TGO member), EFI repair line from Advance Auto (part high pressure braided rubber, part seamless steel tube), bent and flared to a Russell fitting to a Vette LS1 filter. Return line using new clamped rubber (low pressure). Line to engine compartment bent to come up behind the steering shaft, flared to accept Russell fitting. Line in engine compartment flared to accept brass fitting to adapt to an LQ4 line, that was cut and a compression fitting attached to the flared line. Done.
The metal lines handle the pressure with no problem. Any stock carb rubber in the supply side needs to be replaced with high pressure stuff.
Oh, my factory lines were factory V6, so they went up to the driver side of the engine compartment. On V8's, it goes to the passenger side, so you can either bend it up and reverse the fuel rail to connect it on that side, or run all new line up the driver side (which is what I did on the LS1/T56, which was a factory V8 car).
Quote:
sure about that? the factory V8 FI lines should be coming up on the driver side, where as the carbed V8's come in on the passenger. something I just ran into on my 87 TA and 89 RS.Originally Posted by five7kid
Oh, my factory lines were factory V6, so they went up to the driver side of the engine compartment. On V8's, it goes to the passenger side, so you can either bend it up and reverse the fuel rail to connect it on that side, or run all new line up the driver side (which is what I did on the LS1/T56, which was a factory V8 car). OP, if you don't want to do braided from front to back, you can just reuse the metal lines that are in place and just deal with buying a few more adapters to get everything attached up
five7kid
close
Since the topic was CC carb, I was speaking of factory carb'd V8 cars.
Yes, EFI is on the driver side.
Ozz1967
close
Quote:
Maybe I'm just a glutton for punishment? I've finally got mine running mostly well now, just need to fine tune it, been working with NAF on that. Originally Posted by five7kid
Ozz, I know you've been trying to work through CC carb issues. Why do you want to perpetuate the pain? (Said never having had CC carb problems myself.)The main reason is that...for as stupid as it sounds, I want the car to "look" factory for it's year...which means a carb, ac hooked up, smog pump, air lines etc. So I figured I'd look into seeing how much of a pain it would be to make it work with the factory CC carb before going EFI or doing something along those lines which would also mean I would want to be putting in the ECM from whatever donor car I take the motor from and whatever else I need to swap.
