Ls1 problem Help please!!!
Old Nov 21, 2010 | 05:26 PM
belowfire's Avatar
Car: 1986 firebird trans am
Engine: Crate 350 4bbl holly carb
Transmission: turbo 350
Axle/Gears: moser 12 bolt 4.55 posi
ok well i went away for a week and let my baby sit shes a 2001 firebird ws6 i Came back yesterday and tried firing her up but she makes a really bad metal on metal noise and then stalls i tried starting her and giving her gas but she made the noise and my rpms just stayed at zero i have no idea what has happened
here a video of her making this noise.
http://www.youtube.com/watch?v=yzRK7H75_3w
Old Nov 21, 2010 | 07:54 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: Ls1 problem Help please!!!
You'd probably get more help on ls1tech for something like this. Good luck though - that doesn't sound pleasant.
Old Nov 22, 2010 | 12:30 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thread isn't 3rdgen related -
This normally would lead to a closed thread, but being in the LS swap section, it might lead to something useful for an LS swapper later, so I'll leave it open for now just to see where it goes...
Old Nov 22, 2010 | 08:30 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Sounds like a spun bearing or three, maybe even a thrown rod.
Old Nov 22, 2010 | 09:24 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
So who had acess to your keys and your car while you were gone?
That sounds bad. It certainly sounds like a spun bearing, which doesnt happen just sitting there. Did it have oil in it?
Kind of hard to diagnose that from the video though...could be a number of things.
J.
Old Nov 22, 2010 | 01:21 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
That definitely does not sound good at all. Did you check your oil pressure when you started it? Im thinking above comments who had your keys whilst you were gone? Those kinds of sounds dont magically appear for no reason
Old Nov 22, 2010 | 03:57 PM
belowfire's Avatar
Found out that my piston rings are blow so that's not god
Old Nov 22, 2010 | 07:01 PM
Car: 86 Trans AM
How did you determine that? Did you pull it apart? Or did you do this via a compression test. If you just did a compression test, and found some dead cylinders, that could mean other issues as well. A leakdown test would be good if you havent already done one.
I am baffled as to how it went from a running car, to what you have now when all it did was sit for a week... Did the car have issues before?
This just doesnt add up...
J.
Old Nov 22, 2010 | 07:36 PM
belowfire's Avatar
Yea it had some issues before. The owner before me used to race it and had Nos I pulled her apart today and had no piston rings at all dropped my oil pan and the bearinging were broken off sitting in my oil pan honest it dumb founds me that this had happened by not sitting I'm still looking into that issue but looks like I need a new engine
P.s the reason this is in the ls1 swap is because I had bout this car for 3000 bucks off a fluffy kitten and I was using it as a daily driver while I'm redoing my 1986 body and frame getting her ready to swap over the engine and trans
Old Nov 22, 2010 | 07:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
sounds like the bearings got deported
Old Nov 22, 2010 | 10:43 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
fluffy kittens should stick to hondas
Old Nov 23, 2010 | 01:52 PM
Air_Adam's Avatar
Watch the racial stuff guys.... I'm not a PC stickler, but if its not important to the thread, you don't need to add it in...
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
utfan01ss
Sep 28, 2015 12:17 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
sreZ28
Aug 14, 2015 07:48 PM
