TPI Air box vs Other intake config.....
Old Dec 4, 2010 | 05:03 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I have a custom 4" intake that just sits in the engine bay, now the question is, how much will the TPI box with a "RAMAIR" kit restrict the LS1 motor from making power? Trying to find the best set up that can get the most cold air.
Old Dec 5, 2010 | 06:59 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: TPI Air box vs Other intake config.....
does anyone have an idea??
Old Dec 5, 2010 | 08:45 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
The TPI induction setup will flow like half the amount of air that your 4" setup flows. If you want cold air, cut the sheet metal out under your filter and route the tubing out in front of the tire. That's how mine is run, as well as a number of other people here.
Old Dec 5, 2010 | 08:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
run it to the fenders like my slp kit
Old Dec 5, 2010 | 08:52 PM
Engine: ls1, LB9
just an idea
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
bryan623
Aug 10, 2015 11:33 AM
